Thorens TD-320 has a wire suspended through spring held by a plastic grommet to float the tone arm and platter table. How can you find replacements for the grommets? They are a hard black plastic but must be strong to support the weight.
5 Suggested Answers
  • 189 Answers
SOURCE: The tone arm of my Thorens TD 160 need adjustment
HI
My advice to you would be go to AudioKarma.org a hifi forum on the web. I'm sure they will point you in the right direction.
Posted on Jan 16, 2010
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Posted on Nov 27, 2011
STYLUSCITY
  • 271 Answers
SOURCE: Problem with Auto Return on Thorens Turntable TD 147
Hi, contact me direct and I will send you the service manual. John. styluscity@gmail.com
joel_renceha
  • 18 Answers
Leo J. Nesuahecner The bottom of the tone arm shaft has a white plastic cup with a single screw in it. You need to remove a large square plastic cover also with a single screw to access the cup. This cup has a magnet in it. As the arm rotates to the end of the record this magnet trips a switch that pops the solenoid under the start stop lever. By loosening the screw on the white cup you can rotate the cup so the magnet hits it's switch sooner or later . It is touchy so prepare to to spend time fiddling with it. There is a small pointer on the cup you can use to grab with your fingernail to rotate the cup counter or clockwise. Hardest part is standing the table on end and operating all functions with the left hand and rotating the cup to various positions. Remember to gently tighten the screw after each adjustment or it will move when the tone arm is moved.
Posted on Oct 05, 2013
Thorens TD160 super tonearm will not lower
This most likely is a mechanical problem. Does it not work in both the automatic or manual modes? For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me direct through the website. Thank you.
Oct 05, 2013 | Pioneer Audio Players & Recorders
Turntable must be started by hand
This sounds like the stepper motor that drives the turntable is failing. Are there any good DJ shops near to you?
May 20, 2008 | Thorens TD-170 Turntable
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
If you can turn the platter easily by hand, then so should the motor. You can also disconect the power leads to the motor and hook up a PP9 9 volt battery to it. If it\'s slow and easily stopped from rotating then there\'s nothing wrong with the power to the motor and the motor is bad!
Dec 31, 2012 | Audio Players & Recorders
Broken needle on thorens TD 158 turn table.
Needle is a term used with 'record players' from the 60's. A turntable has a Phono Cartridge with a stylus. Depending on the brand / model of said cartridge the stylus may be replaceable. The cartridge certainly is. The tonearm is a delicate precision mechanism that will last lifetime if handled properly.
If you don't understand any of this I discourage you from taking any further actions without a knowledgeable mentor / technician looking over your ahoulder.
Mar 22, 2010 | Audio Players & Recorders
Feb 21, 2010 | Thorens TD-190 Turntable
HI
Jan 11, 2010 | Thorens TD-170 Turntable
Thorens TD 145 does not auto stop
Where did you find the Thorens manual?
Is it the mkII one or simply for the TD-145?
Thank you.
Mar 04, 2009 | Thorens TD158 Turntable
Thump or thud coming from speakers when turntable is tapped
Just wondering how close your speakers are to your tables.Could be the tables pick up the low from the speakers.
Feb 23, 2009 | Technics SL-1200MK5 Turntable
May 05, 2008 | Thorens TD-190 Turntable
 Grubhead
Grubhead
