Question about Bernina Activa 140
For the last few days my aurora ,430 will go about 20 stitches then stop saying a thread broke. I have changed everything, cleaned everything, turned off and restarted everything, reset everything... you name it. I have a monogramming business and have resorted to sitting by my machine and hitting the start button over and over, which is very time consuming and frustrating. What could be the problem and solution?
    Scholar:
  • 89 Answers
Sounds to be that the "check spring" came out if its "flag". Not sure if you want to take it to your repair shop or do it yourself.
Remove side panel/head cover/ end cap.
When threading the machine you thread the check spring when you bring the thread down and up.(sorry I just cant think of a better way to discribe it).
Find the check spring.
There should be a small black plastic part that the check spring is controling, and my guess is that it has came out. This is a comon problem with this machine.
I know this is a horable explanation but this is hard to discribe.
Hope this helps
Posted on Apr 04, 2011
Makes one stitch then abrupt stop with threads bunching up from bottom
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
Feb 11, 2014 | Singer 9960 Quantum Stylist Sewing Machine
Aurora 440 Phantom Thread Breaks
have you tried changing your thread supplier or brand? some brands are stronger and same as people like their coffee differently, some machines have a preference to different thread.
Nov 14, 2013 | Bernina Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
How do you stop stitches bunching up on a Singer Symphonie?
try changing the needle
also try changing the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 21, 2012 | Singer Sewing Machines
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
Machine stops and says thread is broke. Mean while the thread is not broke
Probably one of two issues. There is a sensor in the upper tension that is operated by the check spring assembly. If its broken, twisted or jammed it will sew a few stitches, maybe more and then beep and stop. A service man is the only fix, sorry.
Derek
Nov 30, 2010 | Husqvarna Designer I
Trouble with sensor
The upper thread sensor on most Brother's is activated by the check spring. Either your check spring has broken or is stuck. You may be able to fix this if you can get to it. A drop of oil may be all you need. I may be able to give more specific advise if you tell me what model it is.
Feb 06, 2009 | Brother Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Sewing Machines Logo
103 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
