Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
My Poulan riding mower is very hard to steer and turn. I aired the tires up and checked steering. First time using it since the winter. Any suggestions??
SOURCE: Mower bades
I have a 2007 pollan pro 19 hp mower that i have changed the blades on and they were not reversed threads righty tighty lefty loosey
Posted on Sep 26, 2008
SOURCE: Unsteady riding mower plus loose steering
Jump right in with all four feet and tighten the whole system up. You may have to buy some new parts. Good luck.
Posted on Mar 25, 2009
  • 153 Answers
SOURCE: mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
Posted on May 05, 2009
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 376 Answers
SOURCE: Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
Posted on May 21, 2009
How to get my zero turn husqvarna to steer straight
could be check valve going bad will have to take shop fix check valve 100.00
Sep 14, 2014 | Husqvarna Zero Turn Mower Z5426
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Steering wheel is hard to turn on cub cadet riding lawn mower seems locked up
Start buy checking from steering wheel down the shaft , to gear that does turning, to shaft underneath mower that goes to steering tierods , to tires. Oil and grease will do wonders on any parts that look rusty, or may be tight. Definately check air preasure in your tires. You should be fine.
GOOD LUCK.
Jun 16, 2011 | Cub Cadet Garden
I have a 2 year old Cub Cadet and I find it very hard to steer the wheels during mowing.
First grease the the axles and all steering components associated with steering, there should be grease fittings where you can pump grease into, then make sure your tires are all filled to proper psi. Good Luck...
May 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a riding mower model # 96040015 02 ser. # 1001094003997 and when the steering tires are straight forward one tire is straight and the other tire is at least 20-30 degrees to the outside....
You have a bent steering rod or misalignment. Either way git down there by the steering wheels and check it out.....You must have hit something in your mowing dreams??????
Apr 19, 2011 | Garden
Steering is hard to turn
If it is hard to turn in both directions check power steering pump fluid level. Also with both front wheels off the ground key on engine off, turn the tires manually at one of the front tires and turn with the steering wheel engine off. Check for binding (they will require effort to turn) you are looking for a change in effort.
Nov 23, 2009 | 1989 Toyota Camry
How do i fix the steering on my poulan pro riding mower it has alot of play in it.
first check from steering wheel down to gears to see if they are wore,, if not check the rods to each wheel,, hope this help
Aug 31, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
85 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
