Question about Scotsman Prodigy Air Cooled Cuber C0630MA 32A
I have a Scotsman 650, Model CME650AE-32A, AND THE ICE SEEMS TO BE REAL WET WHEN IT GOES INTO THE BIN BELOW. ALSO SOME WATER RUNS INTO THE BIN WHEN THE ICE DROPS. IS THIS NORMAL?
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
Scotsman ice machine
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman cm250 water overfills runs in bin
the water solenoid valve is leaking by its seat and needs replaced.
Apr 06, 2013 | Scotsman Ice Machine, Cuber, 1825 lb....
I have a SCOTSMAN ICE MAKER MODEL NUMBER CM250AE-1E and the water coming into the machine never stops. It fills the tray until the water runs out the drain in the back of the machine.
I ran a service call on this model today with the same exact problem. I diagnosed it with a bad fill valve. The valve is not closing all the way and therefore lets water in all the time. With yours, the problem could be a bad timer or a bad microswitch or a bad valve. Hard to tell without looking.
Now to find the replacement valve for this thing...
Oct 02, 2012 | Scotsman Ice Maker With Bin Cube Style...
Scotsman model 806 ice machine bin full ight is on and no ice in bin,replaced bin sensor a month ago i cant think of anything else it could be replaced the board last month to and the water inlet valve...
Is there anything hanging down in the beam of the sensors? check sensor connections at the controller make sure there is no moister in it and are making good connections. is your water real hard a lot of minerals dirtying up the eyes. if all of this is clear and sensors are good then nothing else but the control board.
Oct 02, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman cme506
i service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
Apr 14, 2009 | Scotsman Cooled Modular Contour Cuber...
Scotsman Prodigy Air Cooled Cuber C0630MA 32A Logo
179 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
