Question about Dryers
I have a gas Maytag dryer model #SDG515DAWW it makes noise but wont go on.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 01, 2011
Model sdg515daww dryer working but gives no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 18, 2011 | Maytag Dryers
'Screeching' noise, Gas Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Sep 10, 2009 | Maytag SDG4606A Gas Dryer
Maytag dryer sdg515daww stopped working.
I assume this is Gas dryer from the model number having a G.
The door switch may cause the problem. If its not running the dryer thinks the door is open? And the light will also stay off. You can jump around the wires on the door switch and see if it works then if so its switch time.
I don't think a thermal fuse should have anything to do with the light. But that's not a bad idea for quick trouble shooting if a manufacturer would do it. Use a volt meeter to verify the voltage you may have enough for the timer to make noise but not enough to make it turn and the dryer to run.
If there is power then try rotating the tub slightly. The motor may have stuck. Don't turn it too far unless you know which way the drum turns. and try alkways to turn it that direction. Keeps your belts on.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag MDG2706A Gas Dryer
Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Oct 14, 2008 | Maytag Dryers
Maytag gas dryer wont stay hot
Check the exhaust to see if it is clogged. If not, you may need a pair of gas valve coils (not very hard.)
Replace the coils if you see the ignitor glow and shut off, without the gas valve opening up.
Mar 09, 2008 | Kenmore 63942 Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Open Questions:
Dryers Logo
74 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
