Could I "stack" a front
  • 456 Answers
I would not recommend stacking one machine directly on top of another. there are various issues with weight, and movement due to vibration.
what you can do is built a solid "workbench" that you can fit one machine under, and then put the other machine on top of the "bench"
personally i would overbuild the bench, using 2" by 1" wood for the frame, braced and bolted to the wall for stability, and use a 1"thick worktop forv the top of the unit. on the top surface, i would also put a 3/8" wooden beading strip about 1/2" fron the outside edges of the worktop to stop the machine moving with vibration and falling off.
i have done this a number of times when space is limited, although i find it much easier to put tehr dryer on the top as it is the lightest of the 2 units.
hope this helps
Posted on Apr 01, 2011
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
Deactivate child lock on simmens washing machine
On Siemens washing machine to deactivate child lock set program to Easy-Care and hold option down arrow for 5 seconds.
Nov 20, 2012 | Siemens Washing Machines
My model 4`7 kenmore washer does not spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Kenmore 98702 Stacked Washer/Dryer
To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
The machine could handle easily one full laundry basket -- see below.
  • Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Charlie
Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Feb 19, 2010 | Bosch Washing Machines
Can i stack the Bosch front load washer with a kenmore elite front load dryer
There is no stack kit to do what you propose. That said, you may be able to construct a compartment on top of one unit to accept the other.
Aug 02, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
