Question about Toshiba PSAG4U-03M00P Satellite A305-S6861 15.4? Notebook
I need a driver for my cdrom somehow is was uninstalled its a GSA-T40F ATA
    Genius:
  • 1,542 Answers
Hi
if you click on this link it should take you to the toshiba official website to download your driver
www.toshiba.com
go to suppprt/downloads find your make model and operating system
then scroll down to find the driver
download it
install it
restart laptop
hopefully all will be good
good luck
Posted on Apr 02, 2011
My CDROmM is completely gone. It reports that the file is damaged some hoe ("Code 19"). It also haas the following listed after the device: ! HL-DT-ST DVDRAM GSA-T20N ATA. Please help!
Remove the cdrom in your hardware than reboot. The computer will find new hardware and install the drivers or ask you to support the cdrom with the drivers
Jan 13, 2011 | Computers & Internet
The dvd/cdrom drive on my pavillion laptop is not
go to start -> run here in the run box write devmgmt.msc This will lead to device manager here in disk drives or sata-ata remove ur cdrom driver by right clicking it and choose uninstall. This will uninstall the drivers for cdrom and now at the top where ur computer name displayed right click on it and select scan for hardware changes. It will automatically install drivers for it.
May 06, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My laptop acer aspire4730z i got problem with my cd-rom(can't run)Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) ...my cd-rom drive(tsstcorpcd...
You have one of two problems....
1 - The driver for the cdrom drive has become corrupted somehow and needs replacing. Go out to the ACER website and download the cdrom driver specific to your make and model of computer (it is IMPORTANT that you provide specific information in the window boxes to get the correct driver for your hardware.) Once you have the new driver, uninstall the device from within Device Manager. Reboot the computer and when Windows proclaims it has found a new device, select to install the device driver from a specific location. Browse to the folder where you expanded the drivers and let Windows install and update the drivers from that location. OR the other possibility is....
2 - Your cdrom drive has died. Remedy, have it replaced.
Jan 24, 2010 | Acer Computers & Internet
HL-DT-ST DVD-RAM GSA-H55N ATA Device doesn't work
That's most likely your upper/lower filters, or drivers acting up.
Try drivers first, as they are easier and faster to fix. Go to device manager under system properties, and uninstall the device and reinstall it.
If it doesn't work delete the upper and lower filters:
Press windows and R keys type in "regedit" and press enter
double click on "computer" on the new window that came up
double click on "HKEY_LOCAL_MACHINE"
double click on "SYSTEM"
double click on "CurrentControlSet"
double click on "Control"
double click on "Class"
double click on "{4D36E965-E325-11CE-BFC1-08002BE10318}
Dec 27, 2009 | Computers & Internet
I can't print label to cd dvd from my dvd unit
Before you can use a lightscribe facility, you must have 3 things, which are, A DVD Drive thats has a lightscribe capability/function, a lightscribe software, and a lightscribe compatible CDDisk.
From what I can see, your drive is not capable, or does not support lightscribe functionality. I tried to check everything about your system model and I discovered that the capability of your DVD Drive is this :
  • Writable DVD formats: DVD-R (6x, DL [double layer]), DVD-RW (6x), DVD+R (DL [double layer]), DVD-RAM
  • CD formats: CD-R (24x), CD-RW (16x)
Which means your DVD Drive does not support Lightscribe facilities.
You can also check everything about your system from this link :
http://gdgt.com/toshiba/satellite/a305-s6857/specs/
Hope this helps you out.
Jul 13, 2009 | Computers & Internet
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39. HL-DT-ST DVDRAM GSA-T20N ATA Device (code 39) will not work, any help pease? I have the same problem,,my notebook is a...
I read over the solution to the problem by deleting the lower keys in the registry,,restarted and it works fine again,,thank you.
The 1st time I tried it, there was now upper or lower keys because i had uninstalled the driver 1st.
Jan 04, 2009 | Intel Durabook V38263 Notebook
DVD/CDROM NOT WORKING
Hi, it appears that CDW/DVDRAM is only detected in BIOS but in normal windows. This is a known issue from Microsoft eventhough you are using Windows Xp or Vista the CDW/DVDROM is not detected and does not appear in My computer icon. This can be easily fixed by a registry tweaks.
Please click on this link http://support.microsoft.com/kb/929461/en-us and then delete the upper/lowerfilters which is blocking the CDW/DVDROM to appear on your windows.
Hope this helps!!!
Thanks
Sep 11, 2008 | Computers & Internet
Toshiba A305-6825 laptop prolem (no visible CD/DVD Rom drive). In Device Manager: HL-DT-ST dvdram gsa-t40F ATA device error. Media test failure. There appears to be CD/DVD combo drive firmware...
You seem to be onto things (though your problem classification was generic instead of for your Toshiba model A305.) Install all the updated drivers for your laptop from the laptop's support site (Toshiba's, that is) so you can use your drive. Drives fail sometimes, and you could try sticking an old movie or something in there instead of nothing, but it is likely it is just the missing driver.
Jul 19, 2008 | Computers & Internet
Toshiba PSAG4U-03M00P Satellite A305-S6861 15.4? Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
