Question about Whirlpool ACQ128 Air Conditioner
MY ACQ128XRO WHIRLPOOL AC BLOWS AIR BUT IT ONLY BLOWS COLD FOR A SHORT PERIOD OF TIME, THEN IT BLOWS WARM.
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 691 Answers
SOURCE: whirlpool ACQ128XRO air conditioner kept tripping
When it was running (working), did you hear the unit thermostat click on and off; was cold air comming out at all? Check capacitor may be faulty causing the unit overload and trip the breakers. Check the electronic control board might also be bad since the unit is not working. Bad motor can also trip the breakers before it burn out. Fan motor 60 bucks, capacitor 54 bucks and control boad 105 bucks. hope that help some.
Posted on Jul 29, 2009
josetapia162
  • 155 Answers
SOURCE: 4 year old Whirlpool 12000 btu ac does not blow
Most likely it need to be service. Unless you know you stuff dont try it.
call your local air conditioning man!
Posted on Jun 30, 2010
heatman101
  • 43501 Answers
SOURCE: AC JUST BLOWS COOL AIR
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 18, 2010
  • 387 Answers
SOURCE: We just purchased a AC
take it abck is the best thing you can do
Posted on Jul 19, 2011
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
AC blows warm air whil idle or at first start
U could be run on eco a/c where the engine is using the power until it has extra to spare. Warm at start could be simlarly that there is now cold air yet and has to "make" cold air to distribute when ready. See if u can find a setting for reg use. cheers, ps eco saves dollars/euros.
Sep 05, 2012 | 2005 Audi A4
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
My ac only works part of the time
u have a temp door accuator motor shorting out
Jun 30, 2009 | 2002 Chrysler Sebring
2002 bmw 3 series intermittent ac
Sounds like a compressor problem.
Jun 05, 2009 | 2001 BMW 325
AC blows warm air at idle
your a/c fan may not be working or slow, if not then your compressor is starting to fail. you could save it by changing the freon and compressor oil, if not the you have to change it.
Apr 26, 2009 | 2007 Dodge Ram Truck
I think the air compressor is bad in the truck
If your refrigerant level is OK and the truck blows cold air your compressor should be fine, in which case the noise is probably coming from the AC clutch which isn't too expensive or difficult to replace. If it doesn't blow cold air, switch the AC on and watch the compressor. If the clutch engages, but the compressor doesn't turn, the drive belt will squeal loudly and probably start to smoke. In that case it is the compressor which is expensive to replace. Most vehicles have an AC bypass that will temporarily cut out the compressor clutch under heavy load. If you are going uphill with the AC on or accelerating heavily you might notice warm air coming out of the vents for a short period until you let off the gas.
Feb 22, 2009 | Mazda B4000 Cars & Trucks
Whirlpool ACQ128 Air Conditioner Logo
122 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
