Question about Bosch Washing Machines
A brand new washing machine Bosch WAE28363 and after a wash it will not spin the clothes and gives an F-18 error on the electronic display panel. Any thoughts on how to fix?
  • barrielad Aug 06, 2008
    It drains when it is put on the drain function but not after a wash. It's not connected to a tap but is standalone in its own room. I have checked the filter at the front as per instructions but it is clear so not the problem
  • douglas smith May 11, 2010
    does machine drain? and is drain pipe connected to a spigot on the sink trap?
The waste pipe was blocked with a coin. Took it out and is working fine now
Posted on Aug 07, 2008
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Jan 11, 2015 | Zanussi Washing Machines
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
Mar 19, 2014 | Bosch Washing Machines
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Just got a brand new Bosch series 500 DLX and it is giving me E12 and E27 errors.
Just fixed the E27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal.
Oct 14, 2010 | Bosch Washing Machines
Bosch washing machine wont distribute clothes properly before going into spin
1st any washing m/c distribute clothes properly by reach to final spin speed gradually not abrubt so if your drum reach this speed suddenly so it will not distribute clothes properly >
2nd you need to but clothes one by one and must be correct weight not exceed>
so it is clear now i think
thankyou
Jul 09, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Error Code EO6 - Bosch Front Loader WVT2850
Hi
I have have this same problem for 4 years now and engineers always told me it was becuase something may have been caught in the filter yet I clea my filter weekly and use the decaler they sold me on a monthly basis. Appartantly it is to do with the switch ??
Finally they have written my machine off yippee
Jun 25, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Wont spin
Try new brushes in motor you must clean armature.The brushes are worn.
Dec 28, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
