Question about Hoover Vacuums
Hoover 2000W dust manager cyclone- Have had this for about 2 months and the brushes stopped turning thinking that the belt had acme off turned it over to try to get in to look at belt now the bottom wheels have came off and will not go back on have not lost any bits literally just undid one screw! Please help!
  • Hoover Master
  • 756 Answers
By all means ~ take it back to the store... I searched for your model and "problems" and got almost 400 hits like: "cutting out", "burning smells" and just plain "dead" to name a few...
In fact one site gave this model only 1 1/2 Stars! You've GOT to see this Link!
Hoover 2000 VC338
2 months is way too soon to fail ~ unless you clean motels or hotels for a living.
Anthony
Posted on Dec 24, 2017
SOURCE:
reddevil6
  • 1673 Answers
SOURCE: Hoover Vacuum not working - Dust Manager Cyclonic 1800W
Sounds like it got plugged up. I doubt if you can get it exchanged, but to try you would have to take it back where you bought it. But you have a years warranty, take it in to a warranty repair shop to get it repaired. Just take proof of purchase with you.
Posted on Jan 15, 2008
  • 97 Answers
SOURCE: Hoover wind tunnel cyclonic U5780900
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Posted on Oct 02, 2008
RJones1125
  • 373 Answers
SOURCE: How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Posted on Feb 18, 2009
  • 3 Answers
SOURCE: hoover mach 3 cyclone vacuum
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Posted on Mar 01, 2009
ukvacfan
  • 328 Answers
SOURCE: Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Posted on Mar 06, 2009
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
Brush will not turn and machine has stop self-propelling forward.
Two things to check out. 1- Any broken belts that need to be replaced? 2- Brush is frozen and needs to be removed, cleaned and lubricated and reassembled.
My guess is there is a problem with the belts.
Oct 04, 2010 | Hoover U8145-900 Savvy Bagless Upright...
The power bar stopped working. The vaccume is
If its 2 months old I wouldnt stress looking at anything. Box it up and take it back. Something that flimsy doesnt make sense to keep does it?
Apr 29, 2010 | Hoover S3765-040 WindTunnel Bagless...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I have a velocity pet lover 1900 only 2 months old
You have broken the rubber belt that drives the brush. Flip over and remove the old belt and replace it with a new one.
Jim
Jun 10, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Am i going mad? I've just brought an electrolux Cyclone Ultra 2000W hoover. I've got it out of the box and have tried to fix the cover to the unit (i.e the bag free area which collects the dust). It won't...
Take it back to the store and compare it to another one, and possibly have a store manager help you, if they can't get it, then they should give you a different one and make sure that it will work before leaving
Mar 19, 2008 | Vacuums
Vacuums Logo
71 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
