Question about Sport & Outdoor - Others
Any idea where I can get a manual for a Leotax 920 manual? I also see that the fabric piece when I take the lens cover off is ripped...Is this a biggy?
Fabric is ripping after trying to embroider with Designer Ruby. Sounds like needle is about to break as it starts. What am I doing wrong?
Could be your stitch is to small,try a larger one ,also does your machine have the same strength cotton ,
worth a try ,on a spare piece of fabric of course good luck.
Nov 20, 2016 | Sewing Machines
795.77546600 dispenser button assembly replacement?
Haven't worked on that one so I don;t know but you might find your answer in the repair manual here:
http://www.appliancefactoryparts.com/content/pdfs/123619-8.pdf
Nov 23, 2013 | Refrigerators
I have a 2008 saturn sky. When I put the top up the fabric on the passengers side always gets pinched in the frame and I have to keep pulling it out. Is this a common problem. Can it be resolved.
I had the same problem. Check for a tear on the underside of the top..,directly underneath where the fabric gets pinched. It's most likely torn from the metal piece that has popped out of the rubber shroud. Every time you open and close the top, this part rubs...eventually tears...and then pinches when you try to close the top back.
Solution --
1. Bend the metal back into place (hammer if necessary).
2. Glue a piece of velcro (fuzzy side up) to cover the exposed metal (gorilla glue works nice..but don't use too much!!)
3. Glue a piece of vinyl to the underside of the top (covering the rip)...use a good, flexible-type contact cement and let it sit for a couple of days to allow proper adhesion.
4. The velcro will slide on the vinyl and...no more pinched top!
Keith
Sky owner since Nov '06
Aug 10, 2010 | 2007 Saturn Sky Red Line Convertible
How to wash Bugaboo Cameleon seat fabric? As the manual told that all the parts are able to taken apart but I still confused. Especially the seat fabric. there are the back support saw inside. I have no...
If you are talking about the base seat fabric, before you put the seat fabric in the washing machine remove the wooden and foam piece from inside the seat and then throw it in on cold with a gentle cycle. DO NOT put it in the dryer. Hang it to dry. Mine came out great like this. If you are talking about the tailed fabric that goes over the base seat fabric, then just remove the cover and put it in the washer - again NO dryer.
Mar 17, 2010 | Bugaboo Cameleon - Tailored Fabric...
Turns over but won't fire
well the plastic piece are from the timing chain guides are either broken or ripped off,and the metal rattling was probably the timing chain,,i think the timing chain jmped or broke and broke the guides,if thats the car you most likely bent the valves in the head,,,i would remove the cam cover and the timing chain cover and see what you got,you may need a engine
Oct 19, 2009 | 1992 Saturn SL1
When opening len cover I get display on monitor
I do not have a solution to this, but do share the same problem. This was my first digital camera and I was quite happy with the quality of the pictures until it stopped working. I have replaced the camera a long time ago, but wanted to give this little guy a second chance. I have tried to keep the lens open with a piece of tape, and am thinking of breaking it apart to see if I can remove the cover. Any ideas, anyone?
Jun 30, 2009 | Fuji FinePix 2600 Zoom Digital Camera
Broken lens cover **RESUBMITTED to Corrected Camera Type**
It's not really a problem if the lens cover isnt there. The following actually shows how to repair a broken lens cover. But have a feeling yours may be damaged beyond repair, so the next option is removal of the shutters. Be careful that you don't get any of the rubbing alcohol that's spoken of in the following procedures on the lens itself.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 03, 2009 | Canon PowerShot A630 Digital Camera
Sport & Outdoor - Others Logo
46 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
