Question about Dell P2210 Monitor
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
    Guru:
  • 433 Answers
Be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Posted on Apr 01, 2011
  • Tedserious69 Jun 27, 2011
    You need to connect the UPSTREAM USB (located at bottom of monitor) to your PC before the 4 DOWNSTREAM USB ports (2 side, 2bottom) will work.
    Habit-Forming:
  • 61 Answers
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Posted on Dec 09, 2014
Who to use usb ports
Posted on Aug 30, 2012
Dell p2210 menu locked, is there a fix ?
Check with Dell to see if there is some way of reset the electronics in the monitor. If no, then you are SOL
Aug 25, 2017 | Dell Computers & Internet
How do I get P2210 monitor to work with USB with Dell Inspiron 15R that doesn't have a VGA port
The Inspiron 15R should have an HDMI port. You should be able to connect the HDMI to the DVI-D port on the P2210 with a cable like this: http://www.monoprice.com/Product?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2 . Alternatively, you can get an HDMI to Display Port adapter. Connect either cable with the notebook and monitor both off. Then turn on the monitor before turning on the computer. Pressing F1 should send the signal to the monitor. However, if you right click on the desktop (anywhere there isn't a program or icon), you should see some links for DIsplay options. You can use those to select the monitor resolution and whether to use both screens (extended or mirrored) or one at a time.
The most expensive option would be a USB to video adapter, see http://www.startech.com/AV/USB-Video-Adapters/ , or docking station. These come with VGA or other video output ports depending on the model. The USB ports on the monitor are just an integrated hub to plug in an external devices. It doesn't communicate to the display.
I hope this helps.
(The DVI to HDMI cable doesn't supply audio but that doesn't matter in this case. However, you may need to go into the Manage Audio devices control panel and disable sound on the HDMI port. Open the Control Panel (Windows + X in Windows 8 or from the Start Menu with Windows 7). Go to Hardware and Sound and then look for Manage Audio Devices under Sound. In the playback tab, adjust the default audio device by right-clicking on the appropriate device. Then click Apply.)
Jan 25, 2015 | Dell P2210 22 inch Monitor
What is the 2 answer for unlocking the p2210t moniter menu
All answers are in the User Manual :
http://www.manualmonitor.com/dell-p2210
Aug 27, 2014 | Dell P2210 Monitor
My usb port on monitor isn't working. how can i fix this?
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
My Dell Monitor P2210 USB Ports Not working
Do you need a USB cable from one of the USB ports on your computer to a USB port on the monitor?
Feb 04, 2012 | Dell P2210 Monitor
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
http://support.dell.com/support/edocs/monitors/e172fp/QSE172FP.pdf
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Dell P2210 menu is locked, how do I unlock it?
You have to hold down the top and bottom buttons at the same time for around 10-15 seconds and it will eventually display an unlock icon and you are back in business..
Sep 07, 2010 | Dell P2210 Monitor
Dell P2210 Monitor Logo
2,096 people viewed this question
Alun Cox
