Question about Panasonic PT-60LCX64 Television
No picture and red light keeps flashing also fan blade is making a ticking noise then stops
I just had the same problem and after contacting Panasonic via email, they advised me to pull the lamp and check phisically if it was shattered, they were 100% right, once I pulled the lamp I found it to be shattered inside.
Posted on May 09, 2011
Ticking Noise in my Fujitsu Mini Split Indoor Unit
does the ac continue to make the noise even in fan only mode or is only in cooling mode. If only in cooling then it could be a gas related problem or blocked coil.
Nov 07, 2014 | Fujitsu 12RLS Wall Ductless Air...
Magic chef 10 cu fridge makes ticking noise but works fine
Some times refrigerators make a noise that sounds like a tick. It could be caused from the refrigerant flowing through the lines. This usually happens when the refrigerator first starts up and goes away after a few minutes. the other possibility is a fan motor blade taping the shroud from time to time. The refrigerant issue is not something that can be fixed. The fan blade issue could be fixed by moving the fan blade back or froward on the shaft a slight amount. If you have a 10 cu ft refrigerator it may not have a fan.
Apr 05, 2014 | Magic Chef Refrigerators
Dometic caravan rooftop airconditioner fan is making a loud ticking noise
remove the cover off a/c on roof. should be able to see if fan blade or squirrel cage are hitting anywhere while running.
Jan 04, 2014 | Dometic Heating & Cooling
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Very soft ticking noise from the power supply fan
There may be some build up on the fan blades that the compressed air could not free. try using a Q-tip to clean anything stuck on the blades.
Aug 24, 2009 | Computers & Internet
Why does my Jenn Air convection oven make such a LOUD clattery/ticking noise whenever I use it? I think it must be the fan...can you help?
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Ovens
Humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Aug 09, 2008 | Toshiba 62HM95 62" HDTV
Panasonic PT-60LCX64 Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
