Question about Philips Computers & Internet
160gb hard disk (philips easy portable storage)
Not showing when plugged in
    Problem Solver:
  • 13 Answers
go to start->search->all files and folder
search the file named INFCACHE.1
delete that file and reebot your pc.
The computer should now recognize the HD.
Riccardo
Posted on Aug 05, 2008
SOURCE:
No computers will recognize my externaml Hard drive. Its model number is usb160. whenever i plug it in to anything, all it shows is a flashing blue light. Can you please help?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 26, 2010 | Verbatim 160GB USB FireLite: The "drive...
How do i reformat (NTFS) my maxtor Basics 160gb external drive to get it back to 160 - it only shows 149gb
it is usual, that you wont be able to access entire 160gb...certain amount of disk space will be reserved in the HDD for boot sector...
Sep 29, 2010 | Maxtor BASICS Personal Storage 3200...
MY Apple computer all of a sudden is not recognizing my 160GB Firelite. It has power but when plugged in the icon won't appear on the desktop and I can't access the drive? Was working earlier in the day.
Try going to utilities in the applications folder, in utilities select disk utility and see if the drive shows up, if so select repair disk after selecting the SmartDisk. If not showing select your hard drive and run repair permissions and see if it helps. Failing this you need a 3rd party disk repair solution like DiskWarrior. The information is still there!
Feb 22, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
160gb usb 2.0 portable hard drive that is froz
Try plugging it into a different USB port may not be enough power from that port
Dec 06, 2009 | Iomega Computers & Internet
Icon does not show up in my computer when plugged in
Hello
I had this problem a few months ago. Here is how you fix it.
Just follow these steps.
Go to:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the virtual schematic below.
Just right click on the drive click on change drive letter and assign a new drive letter.
Restart your computer and all should be set.
Best regards
Sep 28, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
EXTERNAL TOSHIBA HARD DRIVE WILL NOT FORMAT? WHAT DO i DO?
If your hard drive is recognized by your computer try opening control panel,to administrative tools,to Computer management,to storage, to disk management,by right clicking on drive you can format that drive or delete it.
Jun 28, 2009 | Toshiba 160GB USB 2.0 Portable External...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Verbatim
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
Jan 14, 2009 | Verbatim 160GB USB FireLite: The "drive...
New verbatim 160gb usb external hard drive model # USB160 isnt recognized by my pc.
problem.
Go to:
1. Control Panel
the top.
a drive letter.
9. GOOD LUCK
Nov 21, 2008 | Verbatim 160GB USB FireLite: The "drive...
Freecom 160GB Hard drive not recognised
Drives do fail Nick. Is it powering up [power supply problem?] Plug it in and go to Start/Control Panel/Admin tools/computer management/storage/ removable storage and disk management. See if the disc is recognised there. If it is not, and if the disk is spinning Try putting it into the deep freeze overnight. Plugging in next morning and if it fires up get as much off as possible before it goes down again.
May 20, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
263 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
