Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool side-by-side GS6NBEXRS02 fridge ice dispenser not working (3y.o.). Ice maker works fine. Door switch seems to open/close the ice door hatch fine. When I remove the ice bin, it seems the motor gear does nothing. Tried holding the freezer door switch on the left side while pressing the crush/cube ice switch in door, but no activity on the motor gear. Please help me troubleshoot this further. I have a volt meter I think can tell me more, just not sure where to check next.
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
mikedurland
  • 481 Answers
SOURCE: Ice dispenser in door will not dispense ice
this could be the:
door switch (usually 2 switches, 1 for the light and 1 for the dispenser) auger motor itself the dispenser switch or the plug near the hinge that connects the door the the refrigerator has a bad connection. this connection is hidden under a plastic hinge cap usually.
Posted on Jun 28, 2008
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
SOURCE: Whirlpool Gs5shaxnb02 Ice maker
HI!
In my refrigrator ice is not making . My frig is about one year old side by side. All of a sudden I noticed water stop coming in the ice dispenser. Please advise me what went wrong.
Thanks
Posted on Aug 18, 2008
  • 61 Answers
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Posted on Oct 06, 2008
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
304 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
