Question about ViewSonic Computers & Internet
My view sonic VX2835wm monitor slowyly but surely started to die. 1st symptom: it would shut off with computer then turn back on with blue screen. 2nd symptom: you had to finally disconnect and reconnect power cord, hard restart, to have monitor turn on. 3rd symptom: play with power switch several times, yellow then blue, then flickering of power light, dark screen...that is is....then finally no screen power at all...it is dead.
  • 1,684 Answers
Well the other answers are partly correct, the problem is the power supply board but all of the symptoms go back to the same source. There are parts called capacitors on the power supply board that filter the output power and help provide a steady supply, Over time the will start failing which in turn causes the power supply to output "noise-y" power. The power supply board is easily repairable which will bring the monitor back to live. Here is a link to information on repairing the VX2835 power supply board that should get you going.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=178
I hope this helps,
BuddyMc
Posted on May 09, 2012
  • 6,771 Answers
From your description you have two or three different problems, power supply/inverter board issue and poor color. The cost to repair will be more than a new monitor, I recommend not going any further with this.
Posted on Apr 01, 2011
VX2835wm. When plugging in to wall, screen flashes for about 2 minutes; there is no yellow no blue LED. It will not respond to on off button until it has finished the flashing routine.\r\nThen blue LED...
Hi, According to your problem, Check the adjust switches and readjust the monitor first. You have to repair the PCB of the monitor. Better if you can replace the PCB of the monitor.
Sep 02, 2011 | ViewSonic VX2835wm Monitor
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Aug 21, 2010 | ViewSonic VX2835wm Monitor
Hi every time i turn the computer off...the monitor stays on with bright blue colour on screen....then when i try to turn on the computer back on the monitor stays the same and wont show windows...
Obviously geikalok is retarded and doesn't know the difference between a monitor and a printer.
You have a vary unusual symptom. What happens when you change the resolution of your computer to match what the monitor can do? It should be able to handle 1920 x 1200 so I doubt your resolution is too high. Unfortunately I think you may be having a problem with your main board, and there is also a slight chance your power board is going bad (which can sometimes cause some unusual symptoms). You first should check to make sure the unit is no longer under the 3 year warranty (if it is, go to viewsonic.com). You can open the unit up and check the power board for capacitors that are bad but that is unusual in this model, although the power board going bad from other causes is not unusual in this model. You can measure the power voltages on the power board, but if they are OK then most likely you will have to have the main board replaced. I would recommend contacting Viewsonic.
Aug 14, 2010 | ViewSonic VX2835wm Monitor
The model is vx2835wm lcd display. the screen just stays blank in blue
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
This common problem with ALL LCD monitors.
Post back what you find so it may help other people also.
Apr 10, 2010 | ViewSonic VX2235WM Monitor
When i turn it on the screen lights up and is
More likely to be bad capacitors (bulging/leaking) in the power supply/inverter board just like these Viewsonic here: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find so we can guide you furher and will also help other poeple.
Apr 06, 2010 | ViewSonic VA903B Monitor
Is this right for my broken view sonic VG700B ?? Size: 2.6mm x 342mm Part Number: 26342 Starting Voltage: 1500 Running Voltage: 650 Current: 5ma Wattage: 3.35 Intensity: 34,000 cdm2
Is this information from LCDPARTS.NET? I always remove the old lamp assembly and take an actual measurement of the lamp dimension before I place the order. The diameter is correct, but you should measure the length of the lamp, I know LCDPARTS.NET does give you some idea how to estimate the lamp size.
Are you sure that the lamp is bad, the common symptom of bad lamp is that it has pinkish light color wwen it first start up and slowly turning to normal white color light after warm up.
Jan 21, 2010 | Samsung Viewsonic VG700B Monitor
My ViewSonic 17GA mic is not workin it is inbuilt on screen??
Hello, and sorry to hear about your problems with the View Sonic Monitor
First thing is, do you have a tester or some way to check continuity ?
It is not hard to pull the jack connection from the wire.
The mic leads are the first to go, if you are moving the Monitor around allot.
If you can Ohm the mic jack out, it will tell you weather or not you have a connection to the mic.
If not, you would be better to replace the jack and or cable.
I be-leave this is a standard 8mm male jack and can be found at radio shack.
Before going thru all this trouble, I would find another mic to test the PC connection. This way, you are sure the problem is at the monitor and not the audio input jack
Let me know how it works for you, the monitor is easy to dissemble and the repair is fairly easy.
Hope this information is of help to you.
Readers, please rate your technician, even if you do not agree, that lets the technician know, he is not waisting his time.
Thanks.
John Ray
john@johnrraycomputer.com
Jul 08, 2009 | ViewSonic VX2835wm Monitor
I HAVE VIEW SONIC E70 ,IT IS WORKING FINE BUT WHEN I TURN OFF THE COMPUTER IT IS NOT AUTOMATICALLY SHUT DOWN,I HAVE TO SHUT DOWN THE MONITOR ALSO THIS PROBLEM IS ALSO OCCURS WHEN I TURN ON THE COMPUTER .
Possible Solution: Your Computer may have not configured the Monitor properly, to check, go to Start menu and Right click My Computer and select Manage then when Computer Manager is open go to Device Manager and find your Monitor and check if that device is working properly (right click on Monitor and go to Properties). Hope I helped - donman92
Jun 09, 2009 | ViewSonic E70 17" CRT Monitor
Computers & Internet Logo
222 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
