Question about Sony Ericsson Z550i Cellular Phone
Radio not working
After connecting the headset, I try to locate channels, but none is found. I see that RDS word is greyed in Radio application. Not sure if there is any way to start RDS.
  • dipban Feb 14, 2009
    even after I connect the headset and click on the radio channels, it can not find the channel.
  • shajeela Mar 31, 2009
    I too have the same problem, my search does not work... Please help
    President:
  • 1,952 Answers
Due to pro in receiver in ur head set..it wont locate the channel...better u change ur headset and try
Posted on Aug 07, 2008
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
found.
May 01, 2016 | Huawei Cell Phones
My mad catz headset is not working at all, when i try to connect it the little grey phone bolinks red not blue
The headset's wireless transmitter is malfunctioning. I had the same issue with a Mad Catz headset, and after emailing the company several times I found out their is no way to fix it without purchasing a new one.
Jun 04, 2011 | Mad Catz Bluetooth Headset for PlayStation...
When I press Weather/Snooze the radio emitts a high pitch sound like a whistling. I have the radio set to voice, I have verified the channel 162.4750 for my area. I have a scanner tuned to that same...
Solution #1
Some counties have two frequency channels. check this URL address to see if you have another frequency channel for your area- http://www.nws.noaa.gov/nwr/indexnw.htm. If you do, try the other frequency channel for your area.
Solution #2
You may be receiving a poor reception quality because of where the radio is located or the antenna's positioning. First play with the antenna until you get a better reception. If this doesn't help, try moving it to a location near a window or outside room. If this doesn't help, you may have to buy an external antenna from an electronics store and hook it up to your radio. If you still have your WR-100 Owner's Manual, they have a page in there for reception (page 12), and it lists in there their suggested weather radio antenna.
Solution #3
It may not be anything you've done at all. It could be the weather station's transmitter itself. May you should call your local NWS office and plea your case to them.
Sep 13, 2010 | Midland WR-100 Weather/RDS Radio
I want to on fm without Head phone...i need code.
If you mean Nokia 2310, I don't think it's possible to play radio without headset connected to the handset. I don't believe, nokia has ever developed such a model and moreover it's impossible to play radio on nokia phones via bluetooth. If you mean other model, do let me know. Or is there any other application installed on your phone to run the radio? But in fact the handset needs the headset to run radio, so that i'll act as an antenna. Somebody uses the cut-out jack of the headset to play radio. You can try a trick, play the radio, put on the speaker (loudspeaker), then remove the headset, if it's working you are lucky. But even with Nokia N95, it's not working.
If you are sure that you are asked a code to access the radio without headset, let me know with more details.
Thanks.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia 2310 Cellular Phone
How do i reset the radio i have the code
depends on type of radio. press TP and RDS buttons together and hold until display shows 1000. press channel 1 button repeatedly until the first number of the code is displayed. use button 2 for 2nd number, 3 for 3rd 4 for 4th. when full code is displayed press TP and RDS together and hold until radio comes on or says safe. radio should then work.
May 22, 2010 | 1999 Audi A8
WR-100 Weather/RDS Radio: How do I find out the county code for Pasco count...
Click this link-http://www.nws.noaa.gov/nwr/CntyCov/nwrFL.htm.
You have two frequency channels, select the one that gives the best reception by trying both of them on the radio.
May 17, 2010 | Midland WR-100 Weather/RDS Radio
2005 Dodge Durango RDS radio
I HAD AN AN MVA IN 1/2009 (REAR ENDED ANOTHER VEHICLE) MY RADIO/CD PLAYER WORKED PRIOR/AND IMMEDIATELY AFTER ACCIDENT. THE NEXT DAY MY TRUCK WOULDN’T START, BATTERY WAS COMPLETELY DEAD. I RETRIEVED MY TRUCK 3/2009 ….. MY RADIO WILL PLAY, HOWEVER, I AM UNABLE TO CHANGE MODE FROM TUNER TO CD PLAYER, CD PLAYER JUST MAKES A NOISE AS IF ITS CHANGING DISK, THIS SOUND CAN BE HEARD WHEN I UNLOCK MY DOORS WITH OUT IGNITION ON; .....ANY SOLUTIONS OR ADVICES IS WELCOME
Jun 30, 2009 | 2005 Dodge Durango
1991 chevy s10
It doesn't need an amp, it has one built into the radio. You may have it wired wrong. Please tell me what color the wires are coming from the radio that you have connected to the speakers. Each channel has it's own color, with the black stripe wire being the negative for each channel. Example: the gray wire is positive for front left speaker and the grey with a black stripe is the negative for the front left. Make sure that none of your speaker wires are grounded to the chassis.
Jan 03, 2009 | Sony CDX-L510X CD Player
Using headset jack - unit always transmits
Try plugging in headset BEFORE turning on radio. You should see the word VOX (not iVOX) on your display. At least this is what works for me.
May 11, 2008 | Motorola Talkabout FR60 (14 Channels)...
Sony Ericsson Z550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
