Question about Pioneer GM5400T 2-Channel Bridgeable Amplifier
Well basically my amp just cut and a weird smell came out and now it wont work is it fried?
I have an au series one 5.0 lt after a run when it is at operating temp and you stop for 4 or five minutes it wont start it stumbles wont rev smells weird out of the exhaust.
Don't know much about your vehicle but if weird smell is a little like rotten eggs sounds like your catalitic converter may be pluggin or plugged up...need to have it tested..good luck.
Jun 24, 2015 | Cars & Trucks
How to know if the motherboard is fried
Well, obviously will not boot or even try to power on, also if the power supply is fried as well with the mother it will have a freaking weird smell on the back fan.
Jan 22, 2012 | HP Computers & Internet
I have a 1000 watt amp and the other night the stupid protect light came on and it wont work anymore
that means u fried the amp or try unhooking ur speakers to see if u fried them
Jun 08, 2011 | Car Audio & Video
My sub stopped working today made a weird noise then cut out i had a 500w amp and 500w 10'' subtube i connected the sub to 3 other amp set ups all the amps work and power other subs but my sub wont make...
did you check the fuse if you have one on it. also u want to have more wattage on your speakers than your amp to protect from blowing your speakers.
Jul 29, 2010 | M-Audio Car Audio & Video
I dont know if my amp is blown or not
Usually you will smell something weird if your amp is fried and it would make a pop noise.
But all amps are different. I say its time to be shopping for a new amp
Apr 27, 2010 | Volfenhag ZX-7190 Car Audio Amplifier
My neg and pos got barred in my truck. I checked all the wiring and fuses, all seemed well, the amp boots up but i cant get the protection light to turn off
sorry to say that you proably fried the amp. there is a way to check, find the air vent on the amp, and smell it, if you smell a burnt smell, its fried. you might get lucky and the amp might be under warrenty
May 01, 2009 | MTX X Thunder 300XD Car Amp
Amp problem
its fried, yo!!! you prolly fried the main capacitor, so it may be repairable, but costly. if you fried an ic chip, just forget about it.
Nov 28, 2008 | Jensen JPA285 Car Audio Amplifier
Got power no audio
first take the amp out. smell the amp youll smell a fried or not then test the sub even on home stereo i doubt its blown these set up are 250w max. i bet then you will realize that it is tmhe servo technology easy fix is to get a small external amp then you wont have another problem
Jun 23, 2008 | Infinity BASSLINK Car Subwoofer
Projection TV wil not cut on.
You should first replace the convergence IC's, both of them. Also make sure all the resistors on the convergence IC's are good and not burnt. That's probably what you smelled burning. Good Luck
Jul 11, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Pioneer GM5400T 2-Channel Bridgeable Amplifier Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
