Question about HP DeskJet 6122 InkJet Printer
My hp deskjet 6122 inkjet printer only prints on top half of paper
    Guru:
  • 433 Answers
In office adjust the page settngs from here file - page setup and make it default
best regards
Posted on Apr 01, 2011
Server 2008 drivers for HP deskjet 6122
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with many Windows systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch.
Jul 04, 2012 | HP DeskJet 6122 InkJet Printer
I want to print in grayscale
Try a different driver. "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). All these drivers seem to be the same print quality in my systems.
Feb 03, 2012 | HP DeskJet 6122 InkJet Printer
When a page is completed the printer does not fully eject the paper and it and the next sheet gets crumpled and spoiled I am using hp deskjet 6122
Make sure the printer paper feed is not blocked with any paper. then check that the rollers are clean.
Also you need to make sure that the paper feed has the correct size settings (Usually a slide across guide labeled from a5-a4/letter)
Feb 28, 2011 | HP DeskJet 6122 InkJet Printer
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
I have a HP Deskjet 6122 Printer and I need a driver for Windows 7 that I can load on a flash driver to put on another computer
Windows: "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are resident/included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 14, 2010 | HP DeskJet 6122 InkJet Printer
My printer will select a piece of paper and sounds like it will begin printing, but it doesn't print--just feeds paper through. Prior to this printer was working well--no changes were made---no software...
I downloaded the driver for hp deskjet 990c and reinstalled my printer manually. It now prints just fine--it just thinks it's a 990c as opposed to the 6122 that it really is.
Jan 04, 2010 | HP DeskJet 6122 InkJet Printer
Can i install the HP Deskjet 6122 on a brandnew HP Laptop with vista OS?
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Oct 10, 2009 | HP DeskJet 6122 InkJet Printer
6122 Printer says it is out of paper and will not print test page
Hi Ken,
The user manual says this:
1. Verify the following:
There is sufficient paper in the paper tray (at least ten sheets).
The paper tray is not overly full.
The paper stack is touching the back of the paper tray.
2. Slide the paper guides so they fit firmly against the edges of the paper.
3. Press the Resume button to continue printing.
Sometimes my printer won't print if it has too little or too much paper in the slot. It's a relatively common sensor problem.
Try that.
If all else fails, here's a link to the user manual in pdf form:
http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf
Good luck
Chris (ziraffa)
Dec 22, 2008 | HP DeskJet 6122 InkJet Printer
Hp deskjet 6122 inkjet not printing
try getting a new printer and replace it ask them why it has problems
Aug 09, 2008 | HP DeskJet 6122 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
264 people viewed this question
Seeker5211
Seeker5211
