I believe this model has a belt and I was hoping for tips on how to change it
  • 456 Answers
Hi.
you have not said what type of machine you have, so i will do my best to give fairly universal instructions for the 3 main layouts.
first switch off and unplug the machine and disconnect water and waste pipes.
if it is a front loading machine, you will first have to remove the top of the machine. this is usually held on by two or three screws at the back of the machine. the lid should push back and lift off.
hopefully you will see the motor mounted on the top corner at the back of the drum. this is the most common and easiest setup.
if the motor is underneath, or if it is a top loading machine, you will have to turn the on to its back or side to access the motor underneath.
in all cases, the motor is usually held on with 2 bolts. one of which should be in a slot to allow you to move the motor nearer or further away from the drum. loosen these 2 bolts and push the motor towards the drum. locate the new belt on the motor and around the pulley on the back (or bottom) of the drum and pull the motor away from the drum to tension the belt and tighten the bolts. as a general rule, you should be able to deflect the belt by 1/4 to 1/2 inch at the mid point between the motor and drum pulleys.
ensure the bolts are tightened fully and replace the lid if needed.
reconnect pipes and plug in.
if you want to send in the type and make and model of your machine, i can trry to give more specific instructions, but you should be able to change most belts using the above guide.
Posted on Apr 01, 2011
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
How to replace dryer door switch on whirlpool model len2000jq1
Rob, I believe I may have answered this in an earlier post, here it is again, 1st and 3rd link, scroll down to how to replace dryer belt videos, it will show how to remove top of dryer and get access to door switch.
My LEN2000JQ1 Model Overview from PartSelect ca
Whirlpool Dryer Model LEN2000JQ1 Switch Door Switch
http://www.appliancepartspros.com/parts-for-whirlpool-len2000jq1.html
May 13, 2016 | Whirlpool Dryers
How do i change poer assist belt on hyundai coupe 2.0ltr 2001?
Check the attached links,similar models to yours power steering belt replace.
How To Install Replace Power Steering Belt 2001 06 Hyundai Elantra
Accessory Drive Belts Replacement 2001 Hyundai Accent
How To Install replace Alternator Belt 1999 06 Hyundai Elantra 2 0L
Mar 10, 2016 | Hyundai Cars & Trucks
How tor eplace timing belt
good luck on this one the timing belt on Volvo is very important & IMHO I would not attempt this as if it go's or not fitted correctly your talking big bill to repair I had my dealer do mine the kit consists of timing belt , adjuster & jockey wheel, & its advisable depending on mileage to change the water pump also to change the aux belt along with its adjuster & jockey & to check free wheeling pulley if on your model & I believe that Volvo say 108,000 miles or 6 years old whatever comes first for this service hope this helps
Jan 18, 2014 | Volvo XC90 Cars & Trucks
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
Sep 09, 2013 | Garden
I've got a Maytag model LD9206. It makes a lot of noise when it first starts up, but the noise goes away. The noise is a loud squeak which I believe is probably related to the belt or pullys. How do I...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 06, 2010 | Maytag Dryers
Older model kitchenaid washing machine, model number KAWE660W...FILLS WITH WATER, but will not spin or drain....only hear a faint buzz sound
I believe this machine was actually made by Whirlpool. As such it has a drive coupling instead of a belt. These couplings break every so often. They are inexpensive and fairly easy to replace. I posted a tip on the exact details of changing one. Follow the link below for details.
http://www.fixya.com/support/r3558477-whirlpokenmore_washing_machine__can_hear
Jan 03, 2010 | Washing Machines
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
2000 Sienna Change Plugs and Timing Belt
Ijust did the spark plugs and believe me the front ones are piece of cake, but the rear ones, let me tell you, if you know about mechanics, go for it. There is alot of stuff to remove, including the intake plenum, and those spark plug wires casing that is another story. My best advise is if you have a couple of hundred dollars, that is your best choice. As far as the timing belt goes, pay a car shop, there is probably twice or three times more work involved than changing the spark plugs. siennas were designed to be worked on once or twice every five years (major work of course).
I hope this doesn't dissapoint you
Good luck mate
Aug 07, 2008 | 2000 Toyota Sienna
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
