Question about Philips GOGEAR SA6045 MP3 Player
The battery lasts a short amount of time - Philips GOGEAR SA6045 MP3 Player
    Sergeant:
  • 378 Answers
Http://www.pdasmart.com/pda-battery-center/battery_PHILIPS_Philips-GoGear-SA6045_battery_center.htm
Sounds like a replacement battery is needed. The link above should help you.
It may be cheaper to buy a new MP3 player.
Also you can check with batteries plus. Many times their technicians can replace the battery for you, and you can recycle the old battery there.
Good luck,
Mark
Posted on Apr 01, 2011
How to extend the short battery charge on Zeepad
You can decrease LCD brightness to improve you battery time
Jun 30, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Tip
How to maintain battery life
buy new battery same amphere of your car stalled to by dealer shop,put small amount of oil into battery terminal both positive and negative for anticorrustion. always key off avoid to drain battery every time,check for short circuit any wire fixed it if there's a short circuit.
on Sep 02, 2010 | Honda CR-V Cars & Trucks
Why Power Tool batteries can't charge to 100%?
Batteries wear down over time. The cells inside them don't work as well at holding a charge compared to when they were brand new. So after using them for a while they begin to last a shorter amount of time.
Lithium Ion batteries last longer and don't wear out as quickly. NiMH batteries are next in reliability. And NiCad have their own issues.
Aug 13, 2012 | Drills
Canon PowerShot A530 Digital Camera My problem is everytime I insert new battery in my camera the indicator is always low battery... And when I turn it off and on again sometimes full battery.. Is there...
Hello
If the batteries are indeed new batteries and you are continuing to get this low battery warning, there is a defect within the camera. However, it may or may not be critical.
Test out a new set of batteries, if they last you a typical amount of time, the error is a false reading and can be ignored. However, if the batteries drain at an advanced rate, there is a short in the camera and it will need to be sent in to Canon for service.
Mar 19, 2011 | Canon PowerShot A540 Digital Camera
When last submitted this question came through as a vacuum problem. As listed in the header this is a problem with a Traveling World Time Clock by Eddie Bauer. The screen goes blank. I replace the...
Obviously, something is draining the batteries. It can be slightly oxidized or dirty contacts in the battery compartment, and that, in turn, causes more current draw, exhausting the batteries quickly. Clean the contacts with a soft cloth and alcohol, or a pencil eraser- make sure they're clean. The unit should not draw that much current in a short amount of time. Make sure you're using Alkaline batteries. Other than those things, you're going to have a short somewhere inside the unit, and that's always tough to run down. Hope it's just dirty battery contacts.
Jun 27, 2010 | Health & Beauty
Fuji Finepix 470batteries only last a very short time. Previously
Most of time it is a battery problem.... try with another battery, before purchasing new one....
If another battery does not works then get it serviced.
Battery has certain time period life (mostly it is expressed in, "no. of times charge") after that battery power deteriorates...
Or if battery has been water clogged then also battery power deteriorates.... (for water clogging may happens exposure of battery to humid conditions)
Please rate the answer if you find it useful...
thanks for rating....
Apr 29, 2010 | Fuji FinePix 4700 Zoom Digital Camera
Rings that come with phone are short
It sounds like it's not the fact that the ring tones are short, but that your device is set to go to voicemail in a short amount of time. Call your service provider and they can set the time to a max of 30 seconds before the call is sent to voicemail.
Apr 30, 2009 | LG Vu CU920 Cellular Phone
All the lights on the panel turn on when pushing the brakes
take a look at your brakelight switch, you may have a short somewhere in the circuitry. After a certain amount of time it dislodges itself electrically after a cdertain amount of time. I have no idea of the time lapse. Also check all of your fuses, under the dash and those in the engine compartment. One could be loose.
Apr 19, 2009 | 1998 Jeep Grand Cherokee
Bushnell Holosight short battery life, batteries hot
This sounds like a short. Send the unit for factory service!
Jerry G.
Mar 16, 2008 | Optics
I just bought a westinghouse unplugged vacuum cleaner.( It is new) The design is awesome, and when it works it works great . But it has very short battery life. 1 battery lasts only about 5 minutes, and...
Usually a short battery life means bad battries that aren't holding its charge. Being new I would think it would have a year's warranty on it. Find out who is the closest warranty shop and have them fix it.
Mar 04, 2008 | Vacuums
Philips GOGEAR SA6045 MP3 Player Logo
274 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
