Question about Refrigerators
My amana refrigertor rolls foward when you open the door does it have a wheel lock just purchased model sad2522wrb06 serial #s04326068 email djsmith17@elmore.rr.com
    Sergeant:
  • 378 Answers
Sounds like a very clean kitchen! I would almost like to eat off the floor!
Most refridgerators don't have a wheel lock. Ours didn't. I took a small chunk of play doh and made a small wedge in front of the front wheel.
When we pull it out for cleaning, I pull the hardened play doh off and replace it when I wheel it back in place.
Hope this helps,
Mark
Posted on Apr 01, 2011
Amana front load washer door hinge, problem with line up to close model NFW 200 TW 10 year 2008
you will need to take the top off and push the drum to the rear to locate the door fixing screws and adjust as necessary and or adjust the door lock eric
Dec 27, 2017 | Amana Washing Machines
Why would Hydrostatic tranny lock-up while sitting idle for a minute?
get the back wheels off the groud start engine push foward on pedal force the wheels in forwrard motion keep doing this till it unlocks
Aug 26, 2014 | Garden
Troubleshooting
no the only thing now is to replace the hydro pump about 200.00you might try to foce it into gear buy getting back wheels off the ground push foward on petal while forceing the wheels to roll foward if you here it whine bad pump is bad have to replace it
Aug 23, 2014 | Garden
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Sep 20, 2011 | Amana AFF2534FE Bottom Freezer French...
Why won't my passenger seat lock?
If the seat has a lever to allow entry to rear seat the fnt seat back and seat roll foward[2 door jeep]. Move the seat back back to normal and push loose seat all the way foward and then all the way back.let me know if that helps
Feb 13, 2011 | 2006 Jeep Wrangler
Stearing wheel locked key wont unlock
Try turning the steering wheel while turn the key. If that doesn't work have someone rock the truck foward and backward causing it to roll slightly while you turn the key. If it has tilt wheel try changing the tilt position. Hope this helps.
Jan 12, 2011 | 1984 Ford F 250
My garage door keep opening ,and i cant clise it
For tonight, disconnect garage door and manually roll it down and lock it.
If door doesn't have a locking handle, then you can lock a door with piece of wire or coat hanger wrapped around door wheel and door track.
Then buy new sensors.
To see photos and selection:
Do Google search for: your brand garage door sensors
For example Liftmaster garage door sensors
They cost $20-50
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on door opener and sensors.
Jan 05, 2011 | Garden
How do level out the upper doors on the Amana bottom freezer French Door refrigerator?
The ref is not usually at fault your floor is uneven.
Shim either the left or right rear wheel 1/4' at a time.
This will take the twist out of the box and Lvl. the doors.
Use hard board avail at Home depot.
2x4' sheet and have them cut it into 3 8" strips
then have hem cut one into 4 12' rectangles.
Use the long pices to roll your ref. out onto so you protect your floor.
Use the small ones to shim the rear wheel.
Jan 15, 2010 | Amana AFD2535FE Bottom Freezer French Door...
Stabilinzing
Simply unscrew the "legs" to lower them. I've found the best thing to use is small slip joint pliers. Just grasp the rubber feet and unscrew until the legs are carrying the weight of the fridge.
Nov 12, 2007 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
