Question about Maytag MAH6700AWW Neptune Front-Load Washer
ND lites up - Maytag MAH6700AWW Neptune Front-Load Washer
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
ND is No Drain. Check to see that the pump is running, the drain hose is NOT kinked or folded and that the filter is clean. If a garment made it into the sump it will block the pump inlet and washer with not drain.
The pump is Item 11 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176706
You can access it from the rear access panel. First check to see that it running and then check to see that there is not any debris in the pump. Knowing your going to have to deal with a water mess when you remove hoses.... Remove the tub to pump hose and see if the the tub sump is clear. ( I use a sacrificed wire coat hanger! ) Use your finger to see if you can rotate the impeller freely. Then inspect the impeller area of the pump for any coins or debris... remove same.. re-install hoses and test. Just make sure that the pump to house drain hose is not kinked or clogged.
If the pump is not running perform a resistance check across the 2 motor connection terminals. No resistance = open pump motor winding.
Thanks for choosing FixYa,
Kelly
Posted on Apr 01, 2011
Tip
16x Dvd+-rw Dl Dvd Writer Comparison Guide
Since the introduction of double layer DVD writers, the interest has been quite overwhelming and is why we keep bringing you reviews of these highly popular drives. The anticipation has now turned into down right obsession and it has become a key component in any current or new system build, thanks to the declining prices and continued media hype. Manufacturers are quite aware of the fascination and is why they have each been releasing their own products which excel in at least one area of the testing methodology used in most reviews. This has led to some confusion as to which drive is best suited for the individuals needs. Today, we compare four 16x double layer drives and highlight both the strong and weak points in order to give you a better idead of which drive is best suited for you.
In this comparison guide, we will be looking at four of the top 16x drives to hit the market, the Pioneer DVR-108, NEC ND3500A, Lite-On SOHW-1633s and the new LG GSA-4160B. We will cover everything from design and features to performance and price. Let's beging with a quick look at each of these drives.
As fas as the front bezel design goes, the LG-GSA4160B is by far the most attractive drive of the bunch. However, for thise who are looking for a headphone jack, the Lite-On drive us the only DL writer offering a headphone jack, as well as volume control. The Pioneer and NEC drives, in my opinion, are the ugliest drives, with a very plain look that just wants to make you hide the driver period. Although we only obtained the 4160B in black, all these drives are offered with both white and black bezels. If you opt for the more expensive Pioneer "XL" model, it has the most impressive looks of any drive in the market. However, this will come at a very hefty price tag, considering they contain different firmware as well that offer a few extra features.
So, we have determine which is the sexiest-looking drive, but what about performance? I've dome some extensive testing on each model to determine which is indeed the most impressive of the bunch. But before we show you performance results, let's briefly look at the features and what they have to offer.
* Features
Each one of these drives has there disappointments when it come to features. Let's compare each to see what they really offer.
* DVD Writing
DVD+R DVD-R DVD+RW DVD-RW
LG GSA-4160B 16X 8X 4X 4X
Lite-On SOHW-1633s 16X 8X 4X 4X
NEC ND-3500A 16X 16X 4X 4X
Pioneer DVR-108 16X 16X 4X 4X
While all these drives are indeed 16x models, only two will write to both formats at this speed. The LG GSA-4160B and the Lite-On SOHW-1633s only support 8x DVD-R writing. So if you are one who only prefers this format, the NEC or Pioneer would be the best choice. All of these drives support writing to DVD re-writable media at 4x.
DVD-R9 Double Layer Writing
Write Speed
LG GSA-4160B 2.4x
Lite-On SOHW-1633s 2.4x
NEC ND-3500A 4x
Pioneer DVT-108 4x
The major disappointment with both the LG and the Lite-On 16x drives is the lack of 4x double layer writing support. Pioneer and NEC seem to be the only manufacturers to jump in and release second generation double layer drives supporting much faster 4x writing. In fact, the jump from 2.4x to 4x is quite substantial as we will show you a bit later in this comparison.
DVD-RAM Support
Supported Read Write
LG GSA-4160B YES 5x 5x
Lite-On SOHW-1633s NO NO NO
NEC ND-3500A NO NO NO
Pioneer DVR-108 YES 2X NO
Now this is where both the LG GSA-4120B and GSA-4160B shine above the rest. In fact, it is what has made these drives the most popular DVD writers on the market. Unline the rest in the roundup, it is a triple format burner, offering full support for DVD-RAM media. The other drives do not support it, with the exception of the Pioneer DVR-108 which supports reading of DVD-RAM discs at 2x. I personally don't see the point in offering only read capabilities, but it's at least one extra feature added to distinguish it from the rest. Fast 5x support of the LG GSA-4160 will actually be tested a bit later in this article.
CDR Writing
CDR CDRW
LG GSA-4160B 40x 24x
Lite-On SOHW-1633s 48x 24x
NEC ND-3500A 48x 24x
Pioneer DVR-108 32x 24x
The fastest CDR writers of the bunch are the Lite-On SOHW-1633s and the NEC ND-3500A. With their support for 48x writing, they make a great all-in-one drive for many users. The only drive lacking in this lineup is the Pioneer DVT-108. Why they opted for only 32x writing is still quite puzzling and is actually why I have found that many are choosing the NEC over the Pioneer. The LG GSA-4160B should not be left out of consideration though. We will show you later that the difference in write between 40x and 48x is not much to brag about.
Additional Features
As far as other features go, all these drives have a 2MB buffer but offer some sort of buffer under-run protection, which all work exceptionally well. This is especially useful if you will be burning discs at 16x, which I personally don't recomment just yet. As our individual tests of these drives revealed, burning at this speed is quite unstable, with the exception of the Lite-On SOHW-1633s.
on Dec 21, 2009 | Computers & Internet
1997 intrepid automatic transmission stuck in 2nd gear and dies in other gears check engine lite is on
I recently had that issue with my 99 intrepid. I changed the input and output speed sensors. they cost 130. for both. and now it no longer gets stuck in 2 nd gear and drives more smooth.
Oct 07, 2012 | Dodge Cars & Trucks
I have all lites on but the wireless. I have unplugged and plugged back in . hit the reste button. NOthing still the onluy lite off is the wireless. New laptop can not find it??
Goto admin page of the router connecting it via a cat5 cable to ur desktop or laptop..
check in wireless dat it is activated or not.. nd if yes just check the wifi signal is set 802.1 b/g/n
Feb 26, 2011 | Belkin (F5D7230-4) Router (587009)
Searching parts
try prs eletronics components uk.
Oct 12, 2009 | Gateway FPD2185W 21 in. LCD Television
2000 sonata check engine lite came on, transmission went to 2 nd gear. computer said idler control valv bad.put in new, reset computer, drove 100 yds. check eng lite 2nd gear again, now computer said speed...
The output speed sensor is located on top of the transmission output shaft, this will send speed value to the transmission control module (TCM).
The vehicle speed sensor is installed on the differential of the transmission, and sends speed value to speed gauge on instrument cluster.
Check also IAC valve and look for vacuum leaks using an hand tool gauge(Vacuum Gauge and Fuel Pump Pressure).
Aug 13, 2009 | 2000 Hyundai Sonata
Speedo interment not working and Odometer lites diming
possible short in wiring, dash panel, or sending units
Jun 25, 2009 | 1995 Chevrolet Cavalier
Disney DTD 363-Car 13" tv/dvd
I have xfinity Comcast cable connected to my Disney's CARS TV/DVD combo. I did not have a remote for it because I bought it at yard sale without it. I used Comcast's remote control. I followed their "Searching For Your Code" instructions. #1-turn on your TV. #2-hold SET till red lite blinks twice. #3- enter 9-9-1. The red lite blinks twice. #4-press nd release the CH+ key until TV turns off. #5-once it turns off press SET key nd red lite will blink twice. #6-Now u have locked in ur code. Press power and TV should turn on. Then CH+,CH-,VOL+, and VOL- should work for ur TV.
Apr 16, 2009 | Disney DTD1363-CAR 13" TV/DVD
New super mario
whats the problem, the boss? a particular level? tell me wot the prob is nd I'll tell u how to get through it
Aug 13, 2008 | Nintendo DS Lite Console
Maytag MAH6700AWW Neptune Front-Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
