Question about Dishwashers
This dishwasher model # GLD4408RWW was purchased 8/07/10 from Home Depot. A GE with serial # above.. The water is not draining out. It will go through a cycle, but does not drain the water out of the dishwasher. I am under warranty for one year. Please help or schedule an afternoon appointment next week. We are not available in the mornings. Thank You, Alicia Hubr
gwshaw71
  • 83 Answers
SOURCE: Bosch Dishwasher
you have a 3 year warranty on bosch dishwashers
Posted on Jan 02, 2008
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
SOURCE: Dishwasher will not drain water out after completing the rince or final cycle
Thanks for respsonding, but the problem was a collapsed y-connector at the drain. We think it was an original plumbing error. The clamp was so tight at the connection to the drain, the PVC pipe collapsed. Turns out the problem was six feet away from the dishwasher. Go figure......
Posted on Sep 14, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
localwonder
  • 6784 Answers
SOURCE: Dishwasher won't drain?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jul 15, 2009
Sometime there is a little dirty water left in the bottom and the dishes are dirty
Some models do not have a food grinder, only a food strainer to collect the larger chunks of food which may be partly blocked. the drain to the sink may be partly blocked.
Mar 02, 2016 | Dishwashers
I purchased a hot water heater about two years ago from home depot and lost the reciept. I need to track the purchase by the serial number can that be done
1) Look for brand name of your heater on following .pdf file:
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
2) Home Depot sells GE heaters made by Rheem.
I am assuming that serial number starts with 1209, and that year of manufacture is 09 for 2009.
3) These water heaters have glass vial that breaks when combustion chamber experiences overheating due to dirty combustion parts, clogged air intake, exposure to flammable vapor.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
4) Water heater warranties are usually first-year: full parts, labor and tank. After first year: parts and tank but no labor.
Warranty may be pro-rated and the value diminishes as water heater ages.
http://waterheatertimer.org/How-to-maintain-water-heater.html
5) Warranty may not apply is customer has not followed installation and maintenance as shown in product manual, such as checking anode rod, and yearly service by trained technician.
Dec 06, 2012 | Water Heaters
Dishwasher hot water connection
Tell Home Depot they agreed to include installation with purchase, and if they refuse to honor their agreement, you will sue them in small claims court. To start a small claims action, call your local ton or city court and ask for directions on filing a claim
Jul 22, 2009 | GE Dishwashers
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
Dishwaser Fills But Does Not Run
You may have a problem with the spray arm being blocked or the water valve may not be letting a sufficient amount of water through to get the spray arms activated. If the dishwasher is still in warranty schedule service before it runs out. GE customer service number is 800-626-2000 model and serial numbers and purchase dates are helpful. Ask specifically if any kits are available to fix these problems and if GE is willing to make any concession toward this repair. Good Luck.
Dec 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Dishwasher Speed Cycle Should be 35 minutes but is 50 minutes
u might want to try a dishwasher cleaner the contact a repair man u can use our directory to locate on in ur area
Here to help
Shaun
Nov 16, 2008 | Dishwashers
GE Dishwasher
Hi tucker19,
I'm Harvey the Master Plumber.
Your question is: You just purchased a GE Dishwasher from Home Depot...Its a QuietPower3...and after you run it, there is detergent build up on the detergent dispenser lid and residue on dishes...HEAVY RESIDUE...Why????
Are you useing a dry soap? If so, try a liquid. Make sure it says DISHWASHER soap on it. Also, use half as much liquid as the dry. Some new d/w's can be tempermental that way. If it persists then use the warranty.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Dishwasher
Hi lilwing,
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Thank you,
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Clicking noise from under the dishwasher & Its a new dishwasher
Maggie, what you are hearing is probably the drain pump solenoid. At start the drain pump will get in to get rid of any water and purge the system. It's hard to tell without being there. I would call for service, it won't cost anything. Have the tech check the wash and drain pump assy. Catriver..post back.
Oct 28, 2006 | GE 24 in. GSD4060JSS Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
