Which slot does my camera sd card go into - Computers & Internet
  • Donald Tucker Apr 01, 2011
    Your question was listed under Barcode scanners. My camera has a plastic door that uncaps a slot to insert the sd card into the camera. Then the card can be taken out and used with a photo printer or I can hook up a data USB cable between the camera and my PC.
    Brigadier General:
  • 10,406 Answers
Whichever slot is the correct size for your specific card -- not too big, not too small, and with the "correct" side "up", and with the "correct" edge going in first.
Posted on Apr 01, 2011
Says sd card error
Are you sure it's an SD card? Even though SDHC cards will also fit into the slot, they will not work in the A540. If the card is larger than 2GB then it will not work.
Feb 03, 2013 | Canon PowerShot A540 Digital Camera
Where to insert sd card
Normally the sd card slot will be on the side or in front of the laptop if it has that option. Not all laptops have sd card slots.
If your laptop does not have the sd card slot, then you can purchase a sd card reader that plugs into your usb port on the laptop for less than $20.
Try Tiger Direct at: http://tigerdirect.com
Below is a multiformat sd card reader for $9.99 at Tiger Direct.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=186067&CatId=2825
Also your camera might have come with a cable that plugs into the camera and the other end into the laptop's usb port. Once you have the cable connected, turn the camera on and the computer will recognize it. You can then search through the camera folder for the pictures or videos. If you use this method, you leave the SD card inside the camera.
May 20, 2012 | Computers & Internet
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
The SD slot on my digital camera looks wider than an SD card
It appears to be a normal SD card slot.
The camera can handle cards up to 1GB.
Dec 07, 2009 | Cameras
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
The camera says xd and sd compatible but it seems that the card is getting stuck and wont fit into the slot for the card?? any ideas why? i just bought the camera 2 days ago
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
Jun 29, 2009 | Olympus FE-25 Digital Camera
Computers & Internet Logo
David Payne
David Payne
