Question about Kinderkraft Vermont Crib
I need a Bottom Nylon Slide for the right side Part Number 900 R with a Spring Finger
  • 340 Answers
I am not sure if you have received help for your Kinderkraft crib yet but Products America can help you. We carry the hardware you are missing for your crib. If you still need help please contact us at 800-205-9642 or 800-772-1041 or you can email us at parts@productsamerica.com.
Posted on May 20, 2011
How do i get the case to a dell optiplex 740 open
most dell pc,s have a button or a slide latch the button ore large on the top back edge some have one on top and one on the bottom . the slide latches are on the back looks like a on off slide switch usually near the the bottom about 4 or 5 inches from the bottom on the right side facing the back of the computer . But in your case i think it is screws holding on the side plate , find the finger slot and take the three srews off that side the plate should slide straight back and come off !
Jul 20, 2014 | Dell OptiPlex 740 PC Desktop
Spring on door does not hold door up
The doors have a combination of nylon cord and spring that works through a pulley system and could be the nylon cord or spring. You need to remove the side panel to repair this.
Oct 15, 2013 | LG Dishwashers
Door falls down
Sandra,
You need a door link balance kit for your dishwasher door. It is part number 8194001. Google it and you will see what it is. You can get it at Sears brand central or ebay or any online appliance parts supply store. You will have to slide your dishwasher out a little to replace them. Look along the bottom edges of the right and left side of the dishwasher and you will find that one of the balance link "strings" has snapped. Yes......they use nylon string and not wire cable. Remove the bottom front black toekick panel as well. Very simple job once you gain access to the lower sides of the dishwasher. Suggest replacing both at the same time as if one broke, the other isn't far behind. Hope this helps.
Tom
Aug 04, 2013 | KitchenAid 24 in. KUDS01FLSS Built-In...
Door Drops open
You could have a spring (on both sides) in left or right side of washer "unhooked or broken" You need to open up and check. Normally you open up by 1) Top 2) Back 3) Sides and different washers have screws that need to be taken out. Some springs have a combination of spring and nylon string that just hooks in. This is quite easy to fix with a screwdriver and common sence ....
Apr 21, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
We tried to rekey our kwikset smart key, but couldn't and now the original key doesn't work
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Mar 24, 2010 | Kwikset Professional Door Lock...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Dishwasher Amana ADB2500AW door spring and cable
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Dec 14, 2008 | Amana 24 in. ADB2500AW Built-in Dishwasher
Drivers side headlamp replacement
I do not know what you mean. It is a five minute job to replace one bulb. From inside the engine bay, unscrew the black plastic cap from the headlamp assembly while it is still on the car. It takes about 1/8 of a turn counterclockwise to do this. Set this cap aside. The bulb mount is now exposed. There is a wire spring clip that releases by pushing forward (towards you as you are standing in front of the headlamp) and pulling it to one side. It hinges back in toward the bay and the bulb and clip harness can be withdrawn through the backside. Now, unclip the three wire harness to the bulb by holding the bulb base.Carefully install a new bulb in the harness base and slide it into the housing. Do not get finger oil on the glass - it will greatly shorten the life of the bulb. If you touch the glass, wipe it with alcohol before sliding it into the housing. Secure the clip and reinstall the cap.
Dec 08, 2008 | 1996 Saab 900
Rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Jun 11, 2008 | Janome MyLock 634D Mechanical Sewing...
Replace Battery Cover
to get to the battery door you must remove the back, to remove the back you must remove the top of the grip (shutter button and dial and WT lever). remove top of grip... 1) starting at the bottom of the plastic strip (along the front edge of the grip) that holds the shutter button, slide upward, the strip will bow outward and after about 3/16", the bottom's free. the only other thing holding it in place is a bit of double-stick tape and a similar clip at the top. CAREFUL! there's a spring under the button that's easy to lose. 2) Inside the battery case, front battery, all the way at the top, there's a tiny phillips screw, pull it. 3) peel away the right side rubber grip right by where your thumb meets the W on the W/T lever. 1st hole you'll see is a springy clip, keep going around to the right til you find a screw. pull that. 4) back to the springy clip hole, pushing inward on the finger, the top will come off straight up. leave it hanging, you just need it out of the way so the back can come loose. remove the back... 5) bottom of camera, remove 2 screws nearest the CE label and one outboard of the rearmost battery. 6) viewfinder cap: 4 screws, skinny on top, fatter on the bottom. the cap pops off. 7) lcd cover/frame: pull away from viewfinder(top) edge about 1/4 inch. the bottom's held by fingers; they need to slide to the left 1/8", then that's off. 8) remove screw @ lowerleft of lcd. now the whole back will slide rearward. 1st thing loose is memory door, remove it. slide the back off, out of the way. you'll now see that the battery door is held on by two hinge pins, not one continuous. the rearmost pin will slide left into the memory cover area, and the door will flex enough to remove it toward the front. trickiest part of reassembly is the spring under the shutter button. balance the spring on the camera, put the button into place. hold it in place with the screwdriver through eye of plastic strip, leaves plenty of room to seat the strip. lose a screw? I did, and the least-needed one is the one pulled at #3.
Oct 04, 2006 | Konica Minolta DiMAGE Z1 Digital Camera
Kinderkraft Vermont Crib Logo
Top Kinderkraft Baby Gear Experts
Joyce Nokleby
Ted Maxwell
wcdoc1953
wcdoc1953
Are you a Kinderkraft Baby Gear Expert? Answer questions, earn points and help others
