Question about Oster 76076-010 Hair Trimmer
Oster Model 274 Series A How to replace blades
  • 3 Answers
SOURCE: I have an old Oster adjustable dog trimmer model
YES! YOU NEED TO BUY A NEW BLADE OTHER WISE IT GOIN A PULL THE HAIR
Posted on Jun 27, 2009
SOURCE: pet hair clippers blades move but dont cut.
Do not use regular oil on the clippers.
Instead use OSTER KOOL-LUBE.
We were told the blades become to hot with regular lubricating oil such as 3 & 1.
We bought some KOOL-LUBE from our neighborhood PetsMart and it corrected the problem on both sets of our clippers (one heavy duty clipper for dogs, one regular clipper for humans).
Here is a link to KOOL-LUBE on the PetsMart web site:
http://www.petsmart.com/product/index.jsp?productId=2752831&utm_source=googleproduct&utm_campaign=2011235&utm_medium=cse&mr:trackingCode=A9C8D151-4519-DE11-B0EA-001422107090&mr:referralID=NA
Jan
Posted on Jul 25, 2009
  • 6 Answers
SOURCE: Clippers jam and won't cut when trying to use attachments
I know it sounds simple, but have you tried a good sharpening.
Posted on Aug 15, 2009
wiringlunati
  • 576 Answers
SOURCE: Proffesional Oster clippers model 274-69 seems to be frozen...
First, these are very sensitive to no lubrication. They should be lubricated every use to every few uses. Put a drop or two of light machine oil (sewing machine oil is about right) directly on the cutting blades. That may fix your problem. Also, watch the blades once you getit running and make sure the teeth totally pass each other or it will pull hair -- no fun! The travel of the moving blade is generally adjustable via a large plastic screw on the side of the clipper.
Posted on Dec 06, 2009
philschneide
  • 448 Answers
SOURCE: CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
Posted on Apr 09, 2010
Where can I find oster 182-01 series b blades?
I would check in the manual to find out where you can get replacement parts. I just do not know where to point you because I don't know where you live!
Feb 19, 2017 | Oster Health & Beauty
How do I take off Blade
I'm pretty sure from memory the blade will pull off from the front edge. There should be a black metal bar at the rear end of the blade which you can push in so the blade will pull off.
Jan 05, 2016 | Pets - Others
I have the Oster model 78950-100 clippers. I bought this at Petco, but don't think the carry this model any longer. I need a replacement blade. Is there a Wahl or Andis blade that will fit this...
Have you checked out hair salon supply stores, like Sally Beauty Supply. They will sell generic and brand specific blades for all cutters.
Jul 27, 2011 | Oster 78950-100
I have oster 6550 series a clippers, i installed new blades but they hardly clip any hair, when I loosen the tension the blades "move quicker" but vibrate with a loud noise
the tension should be pre set from the factory, if its more than one blade your having problems with then its likely there is a problem with the clippers.
Mar 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
Dec 05, 2009 | Oster 76076-010 Hair Trimmer
need oil internally gears etc... will fix problem (dry)
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
1,625 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
