Question about Pioneer VSX-819H-K A/V Receiver
My unit will not power up. There is power coming into the unit via power cord. It appears that it is not being redistributed. Unit will not go into standby or will it reset. Fuse is good.
  • Rob Thompson Apr 01, 2011
    There are no lights on the display.
  • 10,594 Answers
Do you get any light or display in unit front when it plugged in wall socket?
Thanks.
Posted on Apr 01, 2011
  • Shahid Electronics
    Shahid Electronics Apr 01, 2011
    Thanks, for update, there is standby power transformer that seems bad, it is located under speaker terminal board, below image shows its location marked with yellow outline.
    Please replace standby power transformer to solve receiver no power problem.
    Let me know if you have additional question.
    Thanks.
Garmin Nuvi 1450 will not turn on
Try performing a soft and or hard reset on the GPS.
The soft reset is done with the unit disconnected from the power cord, press and hold the power button down for at least 10 seconds until the Garmin screen is displayed.
The hard reset is done with the unit disconnected from the power cord and the unit off, press and hold the lower right corner of the screen and press the power button. A prompt will appear asking "Do you really want to erase all user data?". This will erase all favorites that were saved to the unit. Press yes to reset the unit to factory specifications.
Run the Garmin WebUpdater program to install or reinstall the latest software for your device. This will usually fix any issues.
Be sure to download the correct version for PC or Mac.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Dec 25, 2011 | Garmin nuvi 1450 GPS Receiver
Cannot get power to the unit the light indicating power is out
I have the same model as you. I have two transmitters and three headphones actually. Please see below:
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Apr 24, 2010 | RCA WHP140 Consumer Headphones
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
I tried turning on my monitor and it wouldn't turn on. I checked the power cord and everything was connected correctly. Any Idea;s?
The first step is to make sure the plug you have the power cord plugged into is supplying power to the monitor. [surge protector? Check the switch or the reset button]. Check for the powered on light, usually in the power on button on many computer monitors. Yellow usually means a bad connection with the computer. So the monitor is actually on, it just appears off because you have a black screen. Check the video cable linkage to the back of the monitor and the computer's graphics card or digital video out.
If when you "power on" the monitor's on light does not light it means that power is not getting to the unit and you could have a bad power cord. If it is of the universal type that unplugs from the unit you can swap out for a new cord to test this [some monitors have external power supplies as part of the cord and this could be the problem]. If swapping it for another works than that was your problem.
Many monitors though have their power cords mounted via chassis clamps to the unit and have internal power supplies and are not end user serviceable.
If power is making it to the unit there are a handful of possibilities. Unfortunately the majority of them, at that point, involve dis-assembly of the unit's outer casing and is not advisable to an untrained end user. A service call would be required at that point.
Feb 10, 2010 | Mag Innovision InnoVision LT765 17" Flat...
I recently installed a new black ink cartridge but now, every time i print a document, the little box that tells me the ink is low appears on the screen. How can i stop this box from...
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 22, 2008 | Office Equipment & Supplies
Not Power
Yes, the power cord is the problem. Charge via USB, or get the charger that was supposed to originally come with the unit from the manufacturer
Jul 22, 2008 | iLO MP3 Player
Power cord or console problem?
This Could Be The Wrong Power Cord Maybe Overload or Under
load Via The Power Cord.
Jun 14, 2008 | Microsoft Xbox Console
Pioneer VSX-819H-K A/V Receiver Logo
514 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
