My acer extensa t4200 switches itself off, and it can't be switched back on. The battery is fully charged (100%)
    Sergeant:
  • 378 Answers
Unplug the power and pull the battery off and attempt to power it on. Hold the power button on for 30 seconds, release. Hold the power button for 30 more seconds.
Plug it in and attempt to power it on without the battery attached. Acer has some issues with some of their batteries.
If this is the case with yours, I recommend replacing the battery. Contact your local Batteries Plus for a replacement. Their Rayovac batteries have a decent warranty.
Alternatively, there may be a recall on the battery in question. There's been a lot of battery recalls over the past 5 or so years. Check with ACER on it, yours might be involved with it. If so, you may qualify for a free replacement from ACER.
I personally don't have a high regard for ACER customer service. They are difficult to reach, but not impossible.
Good luck,
Mark
Posted on Apr 01, 2011
How to swich on my HTC WINDOWS PHONE 8S ?
Are you 100% sure that its fully charged? Maybe a faulty battery or terminal. Batteries do fail after a time. Does it boot while plugged in?
Oct 06, 2016 | HTC Windows Phone 8S
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Hi I have an acer laptop travel mate , before it was operating well but now it switches of by its self even if the battery is fully charged and when its on power what could be the problem?
switching off by itself could be a sign that it is overheating or over heated and urned itself out. Are the fans clear? were the vents blocked by a thigh, blanket or loose papers underneath?
Feb 26, 2011 | Computers & Internet
I have Acer Extensa 5420. The charger LED is glowing, but the charging light on the laptop is not on. Switching on does not help either. Removed battery and put it back. That did not help either. Any...
Remove the battery and attempt to turn it on with just the ac adapter connected. If this works then it's you battery. If it does not work then try another ac adapter from a local pc shop or electronics store. If it works then that's all you need but, if it doesn't then more than likely it's your dc jack. Although the jack itself is not very expensive it does get costly to have it replaced. If you can take the machine apart, do some basic soldering, and put it back together, then you can order a dc jack online from ebay or meritline or anyone else that supplies them. Have fun and let me know how it went.
Aug 30, 2010 | Acer Extensa 5420-5687 Notebook
My aspire one d-250 battery doent charge
My problem was: Although the Batt Light shows the "charging" the desktop indicators show the battery is at 100%. If you dscinnect the power supply the computer dies.
SOLUTION: I found this worked on both occasion it happened to me occasions.
1. Shut down the netbook.
2. Remove battery for +- 15 min.
3. Replace battery.
4. Do not switch on netbook, ie boot up, until charge light goes to green ie indicates fully charged.
Dec 28, 2009 | Acer Aspire One PC Notebook
Acer extensa 4620z ... enable wifi card permanantly
The switch simply turns the radio on and off, if it can stay in the on position just leave it in the on position. It should stay enabled if the radio is "on". There really is no reason to keep rurning the radio on and off. If you need to disable it, then just go to the device manager and disable it there. The switch is a pain to replace, first you have to find the right one, then the soldering of the switch is another battlle all to itself.
Oct 08, 2009 | Acer Extensa 4620 Notebook
Wont boot up. A/C connected, battery fully charged. Just flashes green light for 1 second when you press power on button.
Hi I am Vortash sorry to say that power supply fault seems to be the most likely answer to this .. and to be honnest with laptops that was 50% of the problems I fixed .. they are also quite exspensive retail so I tend to search on Amazon or Ebay for them .
I have had this problem with a faulty hard drive also it was shorted out so the computer just shut down .. whatevetr it turns out to be this is one for a skilled engineer as replacing components on a 12 layer multiple circuit requires special soldering equipment and conditions and a fair amount of dexterity and skill good eyesight and the patience of a God lol . you could try another hard drive yourself that isn't to difficult if you can borrow or buy a cheap one .. and you can always get a caddy for it after and us it as a secondry drive on the usb if your own isn't faulty .. I hope this helps Vortash
May 17, 2009 | Acer Extensa 4220-2148 Notebook
Pc is telling me to plug it in when the battery is at 90%
The battery needs to be conditioned. To condition a battery, plug in the AC adaptor and charge it to 100%. Unplug the AC adaptor and run the battery completely down to 0% or until the computer shuts itself down or goes into a hibernate mode. Once this occurs, plug the AC adaptor back in and fully re-charge the battery to 100% again. You should now be good to go.
Let me know what happens and if this has solved your problem. Thank you, Binary Bob
Dec 07, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
