Question about Campbell Hausfeld Husky Gravity Feed HVLP Spray Gun, HDS79000AV
I have hds5900 and hvlp580 Husky from Home Depot it came with no manual - I am trying to shoot nitrocellulose lacquer at 50/50 mix and I can not get enough material to shoot - how can I adjust the spray amount?
What kind of oil do I use an iPoulan chainsaw
go to home depot. buy little bottle of husky 2 stroke oil. mix with 1 gallon of gasoline and a bit of stabiliser. good to go.....
Oct 03, 2017 | Garden
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
When I'm spraying the finish (nitrocellulose lacquer) the spray is more like a lot of droplets than a good, even spray. The the finish dries pretty rough, like orange peel.
First make sure that the air flow is not restricted. If air flow is good and the droplets are still too big and not leveling out then you need to thin the lacquer a little. Thin with lacquer thinner a little at a time til you can achieve a fine spray. If the ambient temperture where you are spraying is high then a little lacquer retarder might be necessary. A retarder slows the drying process giving more time for the lacquer to level out.
Apr 12, 2011 | Fuji 2904 Mini - Mite 4 Hvlp Spray System
What is the mix ratio for the Husqvarna 460 x-torq
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil is 50:1 and what Husqvarna says in the manual. You can download a current OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
15 = week produced - March
00198 = 198th unit Husky produced that week
How do you like the your 460? I almost bought 1 myself (opted for 359). More questions or if you need more help please reply below. HTH
Lou
Feb 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need the manual for my Husky 1/2" air impact wrench
Home Depot carries Husky products, Id start with them...
Nov 30, 2009 | Impact Husky® 1/2" Wrench
HOME DEPOT GENERATOR HUSKY 5000 NEED PARTS LOCATED FOR GENERATO
bring the entire thing back... ask to speak with the manager and demand a brand new unit... (husky is exclusive to home depot..fyi)
if they give you push back ask for the district managers phone number (they have to provide or they can be fired) but they will replace it before he gets envolved..
if that fails try posting this in the correct category (this is motorcycles)
Sep 15, 2009 | 2000 Husqvarna TE 610
Gas problem
If it's a Ryobi it is 40:1. If you go to the store, you can buy small bottles that will give that mix if the entire bottle is put into 1 gallon of gas. Ryobi bottles are pretty easy to find. Home depot carries them.
Apr 26, 2009 | Ryobi Cultivator
Campbell Hausfeld Husky Gravity Feed HVLP Spray Gun, HDS79000AV Logo
79 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
