Pen drive not recognised by pc
Pen drive icon available on pc.. but on clicking.. it says insert drive in specified location...
    Problem Solver:
  • 6 Answers
Just check in device manager that your usb is working or not .
if its working then scan your pendrive .
Posted on Aug 07, 2008
HPv165w recognized in Device manager...But cant open it in My computer..
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
Nov 24, 2012 | Electronics - Others
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
I want to make my pendrive bootable to install window xp on my computer
download this file unetbootin-windows-471.exe, then you must have an ISO file of your windows xp, you can install ultraiso or any iso maker available on the web, insert your xp cd then make an iso image out of your xp cd... after having iso file for win xp, insert your pen drive (at least you have 1gig free space on your pen drive) then open unetbootin-windows-471.exe, under the disk image, locate your win xp iso file using the select disk image file button,. then just chose Usb Drive , and also on the drive chose the drive of the usb (check it on my computer and check the drive letter of your pen drive) then click ok... once successful transfer of image to the pen drive, restart pc then make your pen drive to be the 1st boot device
Dec 02, 2010 | Computers & Internet
One I have to insert my pen drive in friend lab tab that Os is Vista that time pen drive ask formate ur drive I gave formate command on that time of my pen drive is not working Locked my pen drive is...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Oct 29, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Inserting by pen drive,pc is getting hang
hello....
Your pendrive hs virus files in it..... You have to format it first.. If you can go into my computer , right click the pen drive icon and format it... or put it in another PC and format and then use it...
Hope it will be useful
Aug 23, 2010 | Computers & Internet
When i insert a pen drive usb device can not recognised message displays and i cannot open my pen drive
in this case you can check whether your usb drive is disable or not
by doing right clickon my computer icon then properties - hardware - device manager - in device manager below you will find usb check if you hav any red cross in that if yes then do a right click and enable it
other wire do a right click on usb and then scan for hardware changes
OR try to to put some other USB device and check if that works or not
Mar 04, 2010 | Kingston 4GB Secure Digital High Capacity...
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Always shown one pen drive icon
1- Unhide Files and Folders in Tolls Menu
2- You will find Autorun file in your Existing Drive. Just Rename or Delete that file.
3- Reboot Your PC
Thats all
-Rajkumar
Jan 27, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Sandisk 4GB pendirve not recognised by PC - Driver issue?
Dear Friend,
I have problem in my pen drive which which built by SAN Disk its storage capacity in 4 GB i am using winxp but this pendrive is not recognize by OS pls solve my problem
Thanks
Aug 09, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
