Question about Briggs Stratton Portable Generator 305cc Engine 8250 Surge Watts 5500 Running Watts Model 030439
Engine runs fine but not putting out any power. thanks
    Scholar:
  • 133 Answers
Try replacing the rectifier. They are fairly inexpensive and a common problem. Ask the Manufacturer if the newer models need to have the fields excited after the new rectifier is installed. I hope this helps.
Posted on Apr 01, 2011
    Master:
    Sergeant:
  • 500 Answers
Is the engine turning the shaft to the generator ? if it has a coupling device is it intact .. is there a reset button on gen output does it need reseting. or is it not working...
Lawn Mower putt putt when filter in place
Your air filter screw may be too long from over tightening air cleaner and crushing the cover. It warpes the carb allowing for gas to leak into carb. Grind or cut off screw alittle or put washer on and don't over tighten. thank you for using fixya.
Jun 12, 2013 | Briggs & Stratton Garden
07 petrol citroen xsara picasso judder/loss power after 1/4 mile from cold
service the car, put correct engine oil in it and also change gear box oil
Apr 03, 2013 | 2007 Citroen Xsara Picasso
Water pump is leaking,my engin is running hotter
if engine is running hotter than normal, test the thermostat in a coffee pot, if it is opening fine, then the water pump is going out, and will definately need to be replaced asap to avoid further and much more costly repairs!!!!
Oct 27, 2009 | Pontiac Montana Cars & Trucks
Power washer loses pressure. Engine runs fine. Taking the nozzel off, squeezing the trigger, and then putting the nozzel back on sometimes remedies the problem. How do I fix it? Thank you.
Your bypass valve is jamming. All you do is take it out, put a smear of o ring grease around the o rings then put back in, make sure you push it all the way in and should fix the problem.
Sep 29, 2009 | Karcher 2500 PSI Pressure Washer
My 1995 Jetta is running fine without the ac on. After I turn the ac on it may drive fine for a while then all of a sudden it loses alot of power and spits and sputters. What could be the problem. Thanks
make sure your plugs and wires are in good condition.also fuel and air filter.the engine has to be well tuned up.because air conditioner compressor put a little load on engine.if engine is not well tuned.the AC will pull it down.cause it to lose power and run rough.
Jul 25, 2009 | Volkswagen Jetta Cars & Trucks
1999 200HP johnson boggs down when put in gear
Check your tank screen. Check your lower unit and the propshaft for fishing line wrapped around it. Check under the cover and observe the wires on the stator which turn to advance the timing. It sounds like you have no torque.
May 12, 2009 | Boating
I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Aug 25, 2008 | Sport & Outdoor - Others
Briggs Stratton Portable Generator  305cc Engine 8250 Surge Watts 5500 Running Watts Model 030439 Logo
325 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
Mike Carew
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
