The furnace wont stay running. there is adequate feul
    Scholar:
  • 133 Answers
I'm guessing you have an oil burner because of the "Adequate Fuel" statement. If so, be VERY careful while following this suggestion, OK? There should be a small inspection hatch on the front above the burner. Be sure everything is turned off and the fire is NOT still burning in the combustion chamber. Use a flash light and look in the inspection hole. If you can't see the end of the burner, use a mirror. If there is oil sitting in the bottom of the chamber, don't fire it. If you can see the end of the burner, it will look something like the picture. What usually happens is the nozzle partially plugs and the spray pattern goes a little goofy. As a result, the oil does not burn completely. Some will build up on the bottom of the chamber, some will create a lot of smoke and some will harden on or around the electrodes. All you can really do is check for unburned oil in the chamber and see if the electrodes are shorted with carbon. If you see a carbon arch on the electrodes, you can VERY gently remove it for a quick fix. If a lot of oil has built up in the chamber, the fire will continue to burn when the thermostat is satisfied and shuts off the burner. I have seen flu pipes red hot from this so be careful in deciding to re-fire it. There are several CRITICAL adjustments that require special tools to accomplish. Regardless of how things work out, you need a service tech. who knows what he is doing. BE CAREFUL! Sorry, my picture is too large. Just go slow and look it all over. If you are not in an emergency situation, call a service guy.
Posted on Apr 01, 2011
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Furnace wont run after running
There are a few posibilities:
1) the oilfilter needs cleaning
2) your pressure reduction bore needs to be changed
3) there is still some air left in the oil-tubes coming from the tank and leads to your burner
The best solution is to call a technician, he'll fix the problem in no time and while he is at it, perhaps he could perform a maintenance
May 29, 2013 | Heating & Cooling
Where is the feul pump relay located on 1992 s10?
Here's where it's at. here's what it look's like.
Feb 17, 2013 | Cars & Trucks
Where is the fusible link that keeps feul pump from running on 1992 s10
there may be a safety shut off switch that has been activated.
Feb 17, 2013 | Chevrolet S 10 Cars & Trucks
My 2004 nissan hardbody 3.0 lt diesel pick up is running out of feul in the pump changed all the filters and checked all feul lines for leaks but nothing can it be electrical or is it the diesel pump it...
the fuel pick-up in the tank has a sock on it to filter out any large debris to keep it from damaging the fuel pump, that sock can become clogged and prevent adequate amounts of fuel from getting to the pump thereby starving the pump
Sep 09, 2012 | Nissan Cars & Trucks
Our furnace keeps shutting down soon after burner ignites inducer motor stays running wont heat until reset switch behind inducer motor is pushed
Sometimes a "Flame Sensor" gets carboned up and does not detect that the furnace has ignited, so it shuts down the fuel source. Might try cleaning that if so equipped.
Dec 05, 2010 | Goodman GPG152407041 15 SEER Packaged...
My goodman furnace model gms95 has gone ape. when the thermostate calls for heat, the furnace kicks on and starts to cycle but it wont stay on long enough to reach the set temp, before it kicks off. and it...
It sounds like your furnace is cycling off because your high temperature limit is tripping. This could be caused by a restriction of intake or outlet airflow. First thing to check is your intake air filter, clean or replace as needed. If that doesn't help, make sure your warm air registers are open, a rule of thumb is at least 60% of the total registers need to be open for adequate airflow. The high temp limits will reset themselves after they cool so that would explain it taking a few "cycles" to reach desired temperature. Good luck and please rate my answer if it was helpful.
Jan 05, 2010 | Goodman Heating & Cooling
Truck wont stay runnin exhaust glowed red
that means you extremely lean. bad problem you can melt pistons that way. test your feul pressure on the feul rail. sounds like a bad feul pump. you catalactyc convertor can cause the same thing if clogged.
Dec 31, 2009 | 1997 Ford F150 Regular Cab
My Ruud Furnace wont stay lit
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
Nov 15, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
