Question about Frigidaire Washing Machines
CAN'T GET THE WASHER OFF THE 8 HR DELAY CYCLE
    Sergeant:
  • 378 Answers
Have you attempted to power off and unplug the washer? This may clear the setting.
Sincerely,
Mark
Posted on Apr 01, 2011
My 8 hr delay button is stuck on help!
Good Morning Friend,
I understand that the 8 hour delay button is stuck on your Frigidaire washer, model# GLTF530DS. With the model number that you have provided, I do not show that there is an 8 hour delay button. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I ask that you please leave me the model number of your appliance. Typically this can be found either on the back of the door or around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire GLTF530DS Front Load Washer
F&P washing machine, start button broken thru cover, not working, how to use Delay Cycle, no lights showing for this
Hi lyn - heres how to do the procedure - load the machine - select the type of wash levels - spin or what ever you want & select delay - once will enable a 1 hr delay - go & have a cuppa, watch a movie or go shopping....
Have fun - cheers...
Jun 30, 2011 | Washing Machines
Who do you set timer on asko 6461 washer?
the timer you are trying to set is for a delay start. so if you set the timer for 1 hr, the machine will start 1 hr later.
Feb 05, 2011 | Asko W6461 Front Load Washer
Turn on machine door locks ready to run but water doesnt start to cycle
Affinity Service manual
The brain might not be getting door lock confirmation due to corrosion in the lock terminals or the door lock itself could be broken.
Aug 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Bosch Classixx 1200 wont start. Ready light is on, door is firmly shut, but start button does not do anything?
these things can be confusing! you may have it set on 'delayed start' or 'soak'- check the other indicator lights! 'soak' would fill and pause for a while, while 'soaking'- 'delayed-start' can be set for an 8 hr. delay on our fridgidair front-loader. don't know about the bosch!
check settings. if ready light is on, there doesn't seem to be a problem with door latch.
good luck!
Oct 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I can't wash immediately because the "wait 8 hrs" button won't turn off
You have to cycle through the delay starts until it gets to off or 0hrs.
May 20, 2009 | GE WSXH208A Front Load Washer
My frigidaire will not go through any cycles>
It may have defaulted to 8 hour delay, ours did after a storm and the power went off, see if the 8 hour delay button is lit, if so press to return to instant wash.... hope this helps
Dec 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Status Lights Blinking
status lights blinking is trying to tell you something in the dishwasher is bad,go to your owners manual to see the fault codes first,then you can try turning the breaker off 30 seconds an on to see if it resets its self,if that does not work i think you might have a bad mother board,thanks-mike
May 27, 2008 | Kenmore 16079 Built-in Dishwasher
Delay Start not working
your delay switch should be separate to your main board it will be faulty the delay switch and should be cheaper than replacing your washer there is nothing you can do if this part is faulty sorry for the bad news m8 it is only a small circuit switch to replace
Aug 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
