Question about Liebherr KGT 3046 Premium
How do defrost a Liebherr Premium fridge freezer? The freezer is iced up. Do I just switch it off?
bomark2002
  • 160 Answers
SOURCE: Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Posted on Oct 21, 2007
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
  • 531 Answers
SOURCE: icing in freezer
you have defrost problem
Posted on Apr 06, 2009
SOURCE: my fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Posted on Mar 08, 2010
How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
Nov 26, 2014 | Liebherr SBSes 74S2 Premium NoFrost
I have a Liebherr 7082. Since there was an ice build up in the freezer, I defrosted it. Since I completed the defrosting, the refrigerator will not turn on.
Is there a fuse in the mains cable. Suspect electrics got wet during defrost. Allow to dry thoroughly before switching back on.
Apr 29, 2012 | Liebherr Refrigerators
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
I have an upright Premium larder fridge,about 18/12 old. It keeps freezing everything. We have 'defrosted' it more than once but it keeps happening. Any ideas?
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 03, 2009 | Liebherr KDPes 3142 Premium
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
Liebherr frost free fridge/freezer
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
The refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
Nov 29, 2007 | Liebherr Premium CTP 3153 Top Freezer...
Liebherr KGT 3046 Premium Logo
1,688 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
