Question about Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
I have no remote for my tv MW27FP1 toshiba how do i use the menu
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
Help
hello! buy a universal remote control. it can control anything that has a remote. it has a menu button. costs around 10 $
Jun 30, 2010 | Toshiba 20AF41 20" TV
My DVD player keeps freezing and skipping scenes.
Try cleaning the optical pickups you can either take covers off and use isopropyl solution with a clean cloth to clean mirror or you can try a cd/dvd cleaning disc from most electronic retailers.
May 23, 2010 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
TV has line through center of screen
thats the VERTICAL OUTPUT IC or TRANSITOR that went bad , need to take unit to a TV repair shop , hope it helps AJ
Nov 19, 2009 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
My Toshiba MW27FP1 will not turn on but is making a buzzing noise. Is this a common problem with this model?
Ur high voltage is dead,FBT,the flyback transformer is dead,the block of plastic with a red wire with a cap hook to a CRT(tv tube).
Oct 03, 2009 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Toshiba code for remote for direct tv
Try these remote codes
Toshiba 018, 021, 023, 071, 085, 090
, 0154 , 0156 ,0060
Aug 01, 2008 | Toshiba 32A33 32" TV
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
DVD player keeps skipping and gets very blocky looking and then sometimes it just stops I tried cleaning both the lenses of the dvd player with dvd lens cleaner disc and cleaning the dvds nothing seems too...
It sounds like the problem is with the DVD's you've been playing. I've gotten those problems before, but not on every DVD. How many different ones did you try playing?
Jun 16, 2007 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
V-chip password
how do i v chip passcode,cause i forgot my passcode
Nov 14, 2006 | Toshiba MW27FP1 27" Flat TV/DVD/VCR Combo
Toshiba MW27FP1 27 in. TV/VCR/DVD Combo Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
