Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
  • 710 Answers
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Posted on Apr 01, 2011
As Roomba 400 Series/Discovery cleans, it communicates with songs, beeps, and indicator lights. It also uses sounds to let you know when there's a problem or it needs maintenance. Here are the most common error codes, what they mean, and how to resolve the problem. If the problem cannot be resolved, click here to contact iRobot Customer Support.
Roomba beeps ...
Likely Cause / What To Do :
Plays 4-note song as Power button blinks RED
Roomba's battery is low and needs recharging Connect Roomba to a Battery Charger (or Home Base) and recharge the battery.
"Ehh"
Roomba's Cliff Sensors are dirty or malfunctioning
Pick up Roomba and turn it over. Check for debris underneath the front bumper and around the Cliff Sensors. Wipe the Cliff Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
Roomba's Side Wheel is stuck or is not touching the ground
Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
"Uh-oh" plus 1 beep
Roomba's Main Brushes stalled
Pick up Roomba and turn it over. Remove the brush guard.
Remove the Main Brushes and inspect them for any obstruction.
"Uh-oh" plus 2 beeps
Roomba's Side Brush stalled
Pick up Roomba and turn it over. Inspect the Side Brush for dirt or obstructions. Remove the Side Brush with a screw driver and check for string or hair wrapped under it. Replace the Side Brush, place Roomba in the center of the room and restart the clean cycle.
"Uh-oh" plus 3 beeps
Roomba's Vacuum stalled
Remove and empty Roomba's Dirt Bin. Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin. Spin the Vacuum Impeller around, shaking out any debris that may be stuck. Replace the grill and the Dirt Bin.
"Uh-oh" plus 4 beeps
Roomba's Side Wheels stalled
Lift Roomba off the floor and place it in the center of the room and restart the clean cycle. If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions. Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle.
"Uh-oh" plus 5 beeps
Roomba's Cliff Sensors are obstructed
Pick up Roomba and turn it over. Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors. Wipe the Cliff Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh" plus 6 beeps
Roomba's Wheel Drop Sensors are overloaded
"Uh-oh" plus 9 beeps
Roomba's Wheel Drop Sensors have failed at startup
Please contact iRobot Customer Support.
"Uh-oh" plus 10 beeps
Roomba's bumper is not registering obstacles
Check to see that Roomba is not stuck in one place and move Roomba away from obstructions. Briskly tap the bumper on all sides several times to loosen any debris that may be lodged in it. Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
Hope this helps sure did help me just wanted to pass on good info as i came to me. Have a blessed day
Wayne W.
Posted on Apr 15, 2011
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Good morning...My brand new Roomba 440 after being charged all night will run on its own for a while...but it bumps into walls or chairs and changes direction as it should, but then it stops in the middle...
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
May 09, 2011 | iRobot Roomba 440 Cordless Robot Vacuum
Roomba 560 won't run correctly
Hey
if it's 5 beeps it says: Drive wheel is stuck
You should clean both , push both in and out and confirm it turns freely
Good luck
Avi
Feb 24, 2010 | iRobot Roomba 560 Robotic Vacuum
My roomba 580 runs perfectly for 10 minutes then stops dead without returning to the charger and without the usual beep to notify you of an error
seems like a battery fault.
can you start it after it stops?
how old is it?
try reset and deep charge it
hope that helps
Dec 28, 2009 | iRobot Roomba 580 Bagless Vacuum
Spins, stops and can't find dock
The problem is your Roomba's bumper. Tap it with your hand about a dozen times, blow it out with compressed air, and then try running the Roomba. If the same thing occurs, call support at 1-877-855-8593. (Be sure to have the Roomba with you when you call.)
May 17, 2009 | iRobot 530 Roomba Vacuuming Robot, White...
Roomba red 4100 cleans in small circle stops starts agains cleans small circle stops then status light comes on and clean button blinks.
When the status light comes on, the Roomba is going to sing "uh-oh," and then beep a number of times. Count the beeps. They're a code that tells you what's wrong with the Roomba. You can check iRobot's website for a chart of beep codes. Search "What is Roomba saying to me?" on the troubleshooting page.
Apr 06, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Vacuum wont run
THE BEST SOLUTION IS TO NEVER BUY A SEARS VACUUM AGAIN. THEY DO NOT LAST AND WARRANTY AND REPAIRS ARE TOO EXSPENSIVE! I BOUGHT THREE OVER TEH YEARS, AND NOW AS YOU KNOW, THREE STRIKES AND SEARS IS OUT!!!!!
Feb 24, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Roomba stops and beeps three times and the max light keeps flashing....
Just fixed my roomba that was doing the stop after 2-5 minutes of running, beep 3 times ect... What I did was took off the back part (the trash bin) removed the 5 screws on the bottom, this removes the top and bottom shell, then I removed the 2 screws that are at the bottom of the vacuum's motor. And I cleaned it with a damp cloth. Once clean I let it air dry. She is running like she is new :-)
Dec 22, 2007 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
1,483 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
