Question about Walgreens By Homedics Automatic Blood Pressure Monitor 1ea
Keeps saying no battery after I add new batteries
    Brigadier General:
  • 4,736 Answers
This usually occurs if the batteries are not facing the right direction or the new batteries you installed are weak. If all else fails, you can contact HoMedics Customer Service on Monday (800-466-3342).
Posted on Apr 01, 2011
My acer 6920 keeps saying no battery is detected
check that the replacement battery casing is not warped by an overheated previous battery stack. Same issue with this laptop.
Apr 05, 2013 | Acer Aspire 6920 Notebook PC
Push the start button on my 94 fatboy. Will not engage starter. New battery but If I jump battery starter will engage. Is this the starter relay and if so how do I replace it
If you're saying that the new battery will not start your bike but when you jump the battery in the bike, it will, I'd say you have a problem with the new battery. When you "jump start" any vehicle by connecting another battery to your battery, you're connecting the batteries in parallel. This keeps the voltage the same but adds the current capabilities of the two batteries together. You either don't have enough battery or your starter is drawing too much current. Check all your connections and see if they're clean. What kind of battery did you buy? It should have been a stock replacement battery of the same size and current capacity.
Good Luck
Steve
Aug 18, 2011 | 1993 Harley Davidson FLSTF Fat boy
Some thing keeps killing my battery
Had broken battery terminal on my wifes car, fixed that but saw a fuse on the battery cable, never saw that before on a car. I wonder if a fuse is not letting your battery charge? Most of the time if you put on a new battery it is a good battery since they don't prepare the battery (add acid etc. ) until it sells.
Sep 01, 2010 | 1999 Buick Park Avenue
My blitz keeps saying insert the battery when it already installe
the batteries dead. you need a new one because after the battery dies it wont awknowledge the charger or battery. same thing happened to me. honestly this phone is a piece of ****. youre gonna have a lot more problems ttrust me. im having a problem with it now.
Jun 30, 2010 | UTStarcom Blitz Cell Phone
Jaguar 2002 s-type battery keeps losing power
You can add some life to your battery by opening it and adding some water. it gives the battery some short term life, but not very reliable, the best way is to install a new battery.
Feb 10, 2010 | 2002 Jaguar S-Type
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
My 2005 Yukon xl slt the gauges, are going past where they should, charging over 18v, fuel gauge way past full, even the fuel mileage computer and tire pressures keeps getting higher, battery light keeps...
I doubt anyone could say what it will take to fix this - this problem requires visual inspection and if that doesn't turn up obvious loose ground cable some where you'll need your volt meter.
Basics - Battery voltage is good and load tests good. A battery problem can cause weird stuff too. You might try a known good battery if no tester is available.
Hooking up jumper cables in reverse polarity can cause problems beyond imagination.
Battery voltage beyond spec's will cause the power train computer to shut down in order to protect itself - it isn't doing that, right?
Add-on equipment ? at this point if grounds and power cables/wires are not indicating voltage drops I would monitor system voltages (a scanner will do nicely here) for spikes. It has got to be a voltage problem effecting so many devices. Disconnect add-ons till you are sure they are not causing the problem.
Think about a Professional, you'll save time and money ? Good Luck
Let us know.
Dave
Mar 13, 2009 | 2005 GMC Yukon Xl Denali
My Samsung Digimax 420 keeps saying low battery!
Check that you are using the correct type of batteries and that they are rechageable as i found i had a similer problem when using just normal non recargeable
Dec 22, 2008 | Samsung Digimax 420 Digital Camera
Walgreens By Homedics Automatic Blood Pressure Monitor 1ea Logo
133 people viewed this question
Top Walgreens Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
