Does the gateway model m350wvn have a function key or key that allow you to connect from the VGA output to a T.V. I have a VGA cable that can connect to the laptop with an S-video and a composit video on the other end so you can connect to a T.V.
    Genius:
  • 1,479 Answers
You can download the manual here, that will tell you.
http://www.retrevo.com/s/Gateway-M350-Laptops-review-manual/id/606ci858/t/1-2/
Posted on Apr 01, 2011
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Hello
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
I cant run my gateway GT5676 pc in normal mode with Samsung TV / Monitor
If I'm understand you correctly you said you have the HDMI Cable and the VGA Cable comming from the Computer to the TV. You should only have one cable. Either use the HDMI from the computer to the HDMI to the TV or use the VGA from the Computer to the VGA on the TV. Once you have the cable connect select your input on the TV. If you have the VGA Cable connected your input to select on the tv will probably be PC or Computer. If you use the HDMI Cable your input to select on the TV will be HDMI.
One you connect the cables and select the input try rebooting the computer and the video might show up automatically on the tv. If not you will have to hit the FN (Function key) + the correct (F1 thru F12) key that corresponds to the external display. The correct key will probably have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct key (F1 thru F12) that toggles the display. The display will toggle on 3 setups (Computer only, TV only, both the TV and Computer).
Now as for not being able to boot up normally that's another issue.
Apr 06, 2012 | Computers & Internet
Im trying to connect my laptop to my tv how can I go about?
Have a look the available ports (connections) on your TV.
There can be; HDMI, S-Video.
Look at the available output connections on your laptop. You might have to purchase a cable which connect them together.
VGA connections can also be made from laptop to TV.
Then you have options of expanding your screen or use function (fn) and look for a function key which will allow a multimedia connection to the screen.
With some screens you go to menu and make appropriate selection e.g VGA if you have used this mode of connection.
Give more details of you laptop; will be able to give a detailed explanation.
Ol the best
Rjn
Sep 20, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
No signal input wen connected to the VGA port of my Dell M1210 (Win 7). using an VGA to DVI cable. If i connect the CG223 to an old laptop (vga) it works fine.
The Dell M1210 hos only a VGA output or s-video output, both being analog. If you are connecting the M1210 VGA to the DVI input on the monitor then this will not work. You need to connect to the VGA input on the monitor.
May 25, 2011 | Eizo CG223WBK Monitor
What do i have to do to be able to use my tv as a secondary monitor using my gateway laptop model mx6708
It depends on what type of tv you are looking to connect it to, it looks like your model has a 15pin Vga output built in which was originally intended for connecting to a destop type pc monitor but some lcd tv`s have vga connection which you can use. If your tv has a vga input you will need to buy a standard vga cable available from most computer stores, even asda sell them now! The procedure to switch displays is to press the Fn key and one of the function keys (normally f4 or f8 but depends on manufacturer, look for a key that has something vaguely resembling two monitors with an arrow between them somewher in the lower section of the key) then you should be able to use the tv as your screen.
Hope this helps, if you need more help let me know what sort of tv your trying to connect to and I`ll see what I can advise.
John
Dec 01, 2010 | Computers & Internet
How can i display a portable swivel projector from my laptop using a vga connection? Once im connected all i see is a color bar screen on the wall, do i press something to enable the picture?
There are different types of video outputs which your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Aug 30, 2010 | Toshiba Satellite A135-S4527 Notebook
I can not connect laptop with projector
Instructions
Things You'll Need:
Laptop computer equipped with a VGA, S-Video or HDMI output.
Overhead projector with the applicable input.
VGA, S-Video or HDMI cable.
Software to ready your content for presentation at the correct screen resolution.
DVI-VGA adapter, if you are using a Mac.
Step 1
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Step 2
Step 3
Step 4
Step 5
Step 6
Connecting a laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Step 7
Hope this helps
Aug 01, 2010 | Acer PD100 Multimedia Projector
How do I program my laptop to work with the vga cable
Your laptop has three video-output options:
* output only to internal screen
* output only to external monitor
* output to both
Look for a 'FN' key on your keyboard, and some extra engraving on one of the 12 "Function" keys.
Press and hold down the FN key, and press the correct Function key, to toggle through the above 3 modes.
Jan 16, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
