Question about Toshiba Portege S100-S1133 Notebook
Upgrading memory on Portege S100
Hello, I want to upgrade my Portege to the 2GB maximum. I have managed to lift the keyboard, however I don't want to damage the plastic sheet which is covering the memory slot under the keyboard. Is there an easy way of doing this without having to remove this plastic sheet?
regards
Kipnae
  • 31 Answers
You might wan to contact toshiba and ask them about upgrade possiblities. I have the same computer and have found that its best to contact them or a proffesional when dealing with upgrades. I would tell you for sure if I had gone through with my upgrades, but that would kill my warranty. Dont forget to rate thanks!
Posted on Dec 28, 2008
SOURCE:
Samsung n150 plus is expandable to how many memory?
The Samsung N150 Laptop comes installed with 1GB of Memory and can be upgraded to a maximum of 2GB Memory. This computer has 1 (one) SO-DIMM memory slot, so to upgrade to 2GB of RAM, you will need to replace the installed RAM module with a single 2GB PC2-5300 DDR2-667 200pin SDRAM SO-DIMM memory module.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Samsung N150 Notebook
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I want to upgrade my memory for a Gateway 310x PC Desktop. What kind of memory and what is the maximum memory I can buy?
It will be having two memory slots.So you can upgrade maximum up to 2GB. You need to use DDR SDRAM with a frequency of 333MHz
Aug 28, 2010 | Gateway 310X PC Desktop
Does Toshiba Portege 3490CT ram can be bigger than 128. If so adv availability & selling outlet please.
The motherboard has 128 MB memory (soldered on board). However there is still empty slot for further upgrade. You can install another 128 MB PC100 SDRAM memory to get maximum of 256 MB.
CompQ
May 09, 2010 | Toshiba Portege 3490CT Notebook
Can I upgrade the RAM of this laptop and the grafic card?
Hi:
Your memory can be upgraded to a maximum of 2Gb of memory.
You have 2 slots, and they can each take a 1Gb stick of PC2-4200 laptop SODIMM memory.
Your laptop has integrated graphics and can't be upgraded
Nov 03, 2009 | Dell Inspiron 630M Notebook
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
Memory upgrade.. toshiba portege 3500
hi..the one of memory located at the lower or under the one slot memory installed..thanks...^_^
May 13, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege S100-S1133 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
