Question about Hoover Dryers
Not heating up and filter carte light is on but filter etc is clear
Filter light is normally on but the thermal cut out on the heater assembly (component on the left hand side was defective. Bypassed this to check if the heater elements were working. and then removed the by pass. this will also work for the thermostat (right hand component) approx £6 for these components as opposed to £30 for the whole heater assmbly
Posted on Aug 06, 2008
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
Motor runs but cart won't go
1 check and clean fuel tank and lines
2 clear air filter, soapy water air dry then apply any air cleaner oil
3 adjust carb / chock
4 check for proper spark replace plug (2.99 )
5 make sure drive belt in good working order.
odds are the carb chock should fix you right up
May 23, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
Why should I use a filtration system for my pool?
I have a pool in my backyard and could not imagine living without a filtration system. It filters out all debris and algae, leaving my pool clean and clear.
Jul 15, 2012 | Blue Wave NFC0131 4-5/8 x 9-3/4 tsc filter...
Watkins vanguard spa will not heat
bad heater element if ok bad recirculation pump
Aug 21, 2017 | Pool & Spa
My printer stoppped working. It has one green light blinking When i try to print the floowing message shows up in the computer: Service error 6C00. Cancel printing and turn the printer off and then back...
Most likely the the ink carts are low or you have a one defective cart. Do steps in sequence
1. Reseat carts 2. Reset the printer. 3. Rpl carts one at a time till you find the defective one.
Feb 21, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Printer won't print magenta
So what does the machine do: Not recognizing the cart (error: insert magenta) or does it not print onto the paper?
In 1# case: Reinsert the magenta cart and make sure that the support is secured above the cart top. If it is recognized: OK.
If not unplug mfc from power. take all carts out. Wait five minutes. Reconnect machine to power. wait until machine demands carts. reinsert cart as demanded and give the right answers (see display).
Machine should run a short cleaning cycle.
In 2# case: Insert full carts well. press menu then start mono (blue) then fourtimes arrow-up (te-index). machine will be in maintenance mode. press 7 then 6 then 4. machine will initialize the carts. after some cleaning cycles machine will be
in mentaenance mode again. Press 9 then 9 to leave mode. press ink etc. to run a test print. If it fails and you cant see any magenta, the valve or filter is clogged and cant be fixed anymore.
Nov 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Dryers Logo
173 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
