Question about Harman Kardon AVR 130 Receiver
My HK AVR-132 doesn't process corectly anymore the signals from optical inputs (DD or DTS 5.1). It happened since I bought a WD TV Live and connected it to the receiver by optical cable. Since then, the sound in the movies with DD or DTS is very poor, the voices are almost unhearable, and what I heard from the movie soundtrack it's only the bass and the ambiance music, vocies are very low. Tried different inputs from cable with DD, WD TV Live, but no luck. The receiver identifies correctly the signal as DD or DTS but the sound is very poor. I can't understand what happened, it worked correctly since 2007...
  • calin1975 Apr 02, 2011
    You are right but in this case the receiver is connected via optical cable directly to the primary source (which is WDTV Live media player).
    My main concern is that the digital sound processor of the reciever is damaged, is there any way to find out? But again I mention that the the receiver show that it correctly acknowledges the digital signal, including the message "DOLBY DIGITAL 3/2/.1 EX OFF" showing the appropriate icons. I tried to reset the receiver to its factory settings but no luck.
    Any other suggestion is welcome.
    Thank you.
    Brigadier General:
  • 8,546 Answers
If you're processing digital audio into the reciver via the TV instead of directly from the source it REALLY originates in (Cable, for example), you are wasting good expensive optical cable and introducing opportunities for digital data problems. I always run the BEST audio and the BEST video directly from their prinmary sources to the BEST electronics that can handle each one. That means they take entitrely different electronic routes from their origins to my eyes and ears.
You need to evaluate what might be happening to the audio on its way (unnecessarily) through the TV to the receiver.
Posted on Apr 01, 2011
    Unbelievable, i just checked again the wiring of the speakers and... surprise, the center speaker which is responsable with the voices in DD or DTS had 1 wire disconnected (probable due to the loose of the screwdriver). Fixed the wire and now the sound is beautiful with voices hearing ok, Thank you again.
  • David Dunn
    David Dunn Apr 02, 2011
    I have been lurking on Fixya for awhile and have yet to hear about a digital processor failing on a single channel. In the data world (which this IS) it's usually complete failure or flawless operation.
    It is ALWAYS WISE to eyeball the relevant connectors before declaring a problem. Look at all of your speakers for tight connections. A loose or vibrating speaker wire can kill an amplifier.
No signal is received in the optical input of a 2000 ONKYO TXD 575 Receiver. Remote controller replacement for this unit too the model of the remote is RC-392M
Hi Ben please check the assignment of that port. The port could be bad. I checked several sites for a replacement remote and they are not available. Thank you Onkyo USA
Dec 29, 2016 | Onkyo Audio Players & Recorders
Why can I not change the setting from pcm to dolby digital on my tv
You don't. You change the signal at the source device end, not the TV.
If you have connected a Blu-ray player or a games console, then set the device audio option to Bitstream. This will send a data stream to the TV that it will decode either as Dolby or DTS depending on the source signal format.
Dolby Digital is only an option for an external AV source connected via HDMI. That's the only way to get a Bitstream signal in to the TV. The TV's internal tuner is only capable of PCM audio. It's a DVB-T tuner (standard definition) rather than the DVB-T2 tuner needed for HD. Even then, only the HD channels are encoded in DD.
Iff your BD player or console is decoding to stereo PCM, then it's doing the same job as the TV. There's a small advantage with one of the audio processing modes in how it limits the dynamic range, but other than that PCM and DD will sound identical. This is especially the case with any TV that has no optical audio out, as in this case. The TV can't pass a DD signal out to an external audio system. So all sound is played via the internal speakers or headphone jack. It'll all sound the same, PCM or DD.
Oct 13, 2014 | Samsung Televison & Video
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I have a harman kardon AVR 132 and have just purchased a Samsung UA55D7000. I am running HDMI from the sammy to my ps3 for video and then an optical cable from the ps3 to my HK for audio and im having...
Hi, You might want to run your ps3's hdmi into your hk, as I'm sure it has hdmi inputs. Using your hk as the audio /visual switcher may resolve this issue-and by the way the hdmi cable has audio built in. I hope this was of some help and thanks for choosing FixYa, good luck Prodzilla.
Apr 20, 2011 | Harman Kardon AVR 130 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
Jan 03, 2009 | Denon AVR688
Denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Denon AVR-3801 Receiver
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Harman Kardon AVR 130 Receiver Logo
427 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
