Question about Refrigerators
Kitchenaid superba side by side model#kssc42qks01 my ice dispenser switch needs to be replaced,but i can not fiqure out how to get to it i.e. remove ice dispenser panel on the ref. door to access the switch
  • 2 more comments
  • jeffreyihabe Apr 02, 2011
    ZjLimited, close but no cigar, see diagram #12,dispenser front, that is the part i need to remove,to get to the ice lever relay switch. I have the switch already .How do you remove it?
  • jeffreyihabe Apr 03, 2011
    your manual is from the wrong ref. right area, my ref is a kitchenaid superba kssc42qks01, serial # qm4012650 please try again
    right area wrong refrigerator please check model #kssc42qks01 or kssc42qkso1
    thank you, that was exactly what i needed
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Download the manual below and see page 23 (Pictures)
http://www.affordableappliance.com/Download%20Folder/Whirlpool-Roper-Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf
1. Disconnect the unit from the electrical supply.
2. Pull out and unclip the drip tray on the ice and water dispenser compartment.
3. Remove the screws from the ice and water dispenser compartment front panel and
turn it over. The selector switch pack and dispenser switches are now accessible for testing.
Thanks for choosing FixYa,
Kelly
Posted on Apr 02, 2011
  • 17,970 Answers
Here is a link for parts diagram of your model: kssc42qks01
Look at Diagram 15; you have to take the ice maker out and take it apart to change it, by removing the Cover 18, the screws #17 and #30 and #28.
Here is a THREAD LINK that which included the ice maker repair manual online, it will tell you how to remove your ice maker and take it apart to change that stripper: Kenmore & Whirlpool Ice Maker LED Blinking Codes
Hope helps.
Posted on Apr 01, 2011
How to replace kitchenaid superba light bulb
The light bulb on the water/ice dispenser on our Kitchenaid Superba side by side refrig needs replacement. Easy! Right?
However it is screwed in so tightly and the location is behind the panel is so small, it it very difficult to get a grip on it to unscrew it!
We,ve tried rubber gloves, WD-40 and an Exacto knife(w/ fuse turned off!) and still cannot get this very annoying light bulb out!!
Does anyone have any ideas or can we remove panel it hides behind to get to it!!!???
Thanks for any info on this should be simple issue!!
Susan M
Jan 15, 2012 | KitchenAid Superba Architect KSCS25INSS...
ICEMAKER HAS NO WATER IN IT AND ICE STRIPPER NOT MOVING BUT WATER DISPENSER WORKS KITCHENAID SUPERBA MODEL #KSCS23INBL00 SIDE BY SIDE WITH ICE AND WATER DISPENSER IN DOOR
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Face plate around ice maker/water dispenser needs to be removed.
there are screws on the bottom of the plate. re,oive the drain pan underneith the dispenser and the screws are underneith that.
Apr 04, 2009 | KitchenAid Refrigerators
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Need to replace direct drive drum on Kitchenaid Superba side by side
May need to know your entire model # located on the inside in the refrigerator section. That plastic piece may unscrew but be a reverse thread.
Oct 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
