Question about Biostar 945GC-M7 TE Motherboard - v6.0, Intel 945GC, Socket 775, ATX, Audio, Video, PCI Express, 10
My mother board is not booting up. I can here the hard drive boot up the CPU fan spin but no video signal, no beep.
  • Biostar Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on Apr 01, 2011
Continuous beep motherboard will not boot
check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Mar 24, 2014 | HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775...
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
Aug 03, 2010 | Acer (ACERMOTHERBOARD)
Mother Board
if it has 2 video cards or had 2 might be disabled in bios. if not and it does not boot at all then it could be CPU Powersupply or RAM, i would start with removing RAM and see if it beeps if it does Power Supply migh be ok, put one stick of RAM back in snd see if it boots swap RAM Slots and stic around to make sure its not a RAM Problem. if still no video and just spinning fans its Trial anf error of the CPU and Power Supply i know it **** but if you have a PoSupply tester that would rule that out. if you are savy enough to remove CPU look for burnning and smell for Burn. Good Luck
Feb 24, 2010 | Intel Motherboard
The desktop won't reboot. The power light stays yellow. I hear a fan running, but the monitor says no signal.
If your fan runs and the hard drive spins up, then you have a video card problem.
I'd do this: Disconnect everything inside the case but the CPU, memory, and video. Now try to boot. Also observe the fan on the CPU--does it spin?
If this fails, then your video has probably gone bad. Also--does your computer usually give you a "beep" when it starts up? If so, is it giving you a beep now? If not, you're failing the hardware startup test (POST).
So, your problem may be the video card. If your video is part of the motherboard, then you need to replace the motherboard.
Oct 01, 2009 | Computers & Internet
IBM Think Center A51, 8131-35U will not boot up. Fan comes on but nothing else. Power Supply checks out good. If it is a mother board problem, is it fixable? I tried another hard drive and I do get a...
IF your systems turns on no beeps ...everything seems to work just no display on the screen then i guess would should try discharging your system - ie un plug the power cord take out the Motherboard ,ram , basically take everything apart leave it for a day and connect everything back again ti should work
Sep 05, 2009 | IBM Computers & Internet
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Computer Won't Boot (Anything?)
ok sounds like a bad power supply , i would get a new one
Jan 21, 2008 | Computers & Internet
Biostar 945GC-M7 TE Motherboard - v6.0, Intel 945GC, Socket 775, ATX, Audio, Video, PCI Express, 10 Logo
57 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
