Question about Refrigerators
No the baskets dont fit they keep on falling into the freezer
  • 415 Answers
You have to remove one side of the basket supports and place a spacer and replace it with a longer screw with the same width as you spacer plus the orginal screw length. And do this to the baskets that are falling down.
Posted on Apr 01, 2011
Electrolux freezer basket
it has to be in the holders on the side rail for the basket so it does not twist and fall down make sure it is clipped in
Mar 31, 2014 | Electrolux EW23BC71IS Energy Star Counter...
Our two lower slide-in baskets will not stay on track. Even when the load has been reduced, the baskets fall off the track. I have tried to bend the sides to better reach the track, but it doesn't work. ...
No, very rarely internal shelves can be moved between generations. Unfortunately all you can do is an improvisation to keep them in place: you need to make the channel walls higher by gluing some small pieces of thick plastic on them using a powerful adhesive - not superglue, something like Loctite Sumo Glue.
Sep 10, 2010 | Kenmore Freezers
How do you adjust freezer basket dividers?
We have a similar, though not identical Maytag/Whirlpool refrigerator with bottom freezer. My comments refer to our specific freezer, it is possible that there is some variance in the freezer baskets. Although it LOOKS like you ought to be able to adjust the divider from side to side, with our basket, you CANNOT. the key is to look at the spacing of the wire pieces that make up the basket body. On ours, the spacing at the center, where the divider is factory mounted, is wider than all the adjacent wire pieces. This means that in locations other than the center, the divider does not fit. We just removed the divider to give more flexible placement of items. To remove the divider I suggest first pulling the entire basket out of the freezer. Take your food out so you can turn the basket sideways, and you will see the clip mechanism that is built-in to the divider itself. You need to use a flat screwdriver or similar tool to flex the inner part of the clip back and then wiggle the divider until it pops free of the basket. Repeat process on the other end of the divider.
Aug 10, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Baskets fall off guides
local technicain called kenmore and found a part number that is suppose to work....i'll let you know
Jun 23, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer Baskets fall off Guides
I have the same freezer and have the same problem with the baskets. I hope they come up with a solution because my baskets are inoperable right now...
Apr 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
Shelves that wont stay
I had the same problem. With the basket install empty I notice there was about ¼" gap from the bar the far most side of the side rail. SO I removed the left side rail and found a peice of laminate flooring and cut it to the same size of the the bracket (also predrill the holes so the screw holes match up). I had to buy 3 new screws that were ½" longer the orginal. I reassembled the wood and rail bracket . I then slid the basket in the rail, then started the load the backet up with frozen items. It works perfectly. The basket does not fall any more! Total cost... 3 screws ($0.15).
Nov 18, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire Upright freezer Baskey
remove the basket sliders frome each side and install a couple of nylon washers between the slide and the side of the freezer on each side it will narrow the distance and the nylon washers will not rust
Mar 24, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
