Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
When I plug my SanDisk 2gb into a port no prompts come up (it does light up though) to instruct me what to do to copy all photo's in my gallery...suggestions???? I am using a Windows Vista computer (160 gb hard drive) w/ 512 MB DDR2
  • SanDisk Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall once you have the usb drive running
click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the destination drive right click select paste or hold the mouse cursor the file/s drag them to scan disc then drop them hope this helps
Posted on Apr 01, 2011
How do you sandisk photo form one couputer to other
The USB drive is recognized as an ordinary hard drive with a letter, easily seen in Windows Explorer. Use drag and drop to copy and paste what ever you want including photos or music, any type of file, no software, program od driver is necessary.
Sep 12, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How to add documents on sandisk 4gb flash drive
I would assume you want to save documents to the flash drive, if this is correct, plug the flash drive to a USB port on the computer and once it is detected in My Computer (or you may get a prompt for it), just open its folder and you can copy/save files from your computer to the flash drive. NOTE: you may need to format the flash drive first using your computer if it is the first time you'll be using it.
Sep 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have just purchased a sandisk cruzer to transfer photos from pc how to i do this as there are no instructions
just insert the usb disk and go to my computer and copy and paste the folder which you want to transfer.in my computer you will see the drive latter of usb drive.
Dec 31, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I lost all my photos and the drive doesn't work anymore. help
Once these bad boys go bad.
You usually have to reformat them.
BUT this would certainly destroy any chance of reviving old photo's.
Try putting the stick into another USB port.
Even on another machine.
You may get lucky and have the photo's re-appear.
Copy quickly to another safe drive/CD what ever.
There are two different types of USB ports 1.0 and 2.0.
Oct 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i plug my sandisk 2gb it dosent work!
Have you tried every USB port? Do any other things work on your USB ports? Is it USB 2.0 and your computer only does USB 1.0? Have you tried the sandisk in another computer? Does the USB port feel loose when the sandisk is inserted? Sounds like the sandisk may be bad.
Sep 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Cruzer Micro 8GB flash drive - no user manual
Plug it into the USB port. Press Windows-E to bring up the Explorer window, or start My Computer and open the removable drive.
You can then drag&drop files to/from the flash drive just as you do on the hard drive.
Feb 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Open Windows Explorer on your PC. You should see it there when you expand the "my computer" tree on the left side (click the + symbol next to 'my computer'). It will show up as a drive letter, depending on how many hard drives and optical drives you have in your system, it could be drive letter "E", "F" or even higher. It will probably say "Cruzer" next to the drive letter. All you have to do is drag and drop your files onto the drive letter. Simple, you don't need instructions.
Feb 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer® Micro 2GB WON'T Download pictures
Try using Windows Explorer to copy them. I'll try to help you out.
When you plug the drive in and a window pops up, select "Open folder to view files using Windows Explorer". If they show up in the right pane as thumbnails, select View>Details from the menu at the top.
Left click the top picture, then scroll all the way down to the bottom. Press and hold the <Shift> key, then left click the last picture in the list. This should highlight all the files.
Right click on any of the pics, then go down to "Send to...". This opens several choices, but you probably should choose "My Documents". This will copy all of your pics into your My Documents folder.
Once you get them there you can move them to your My Pictures folder in much the same way.
Oct 03, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
48 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
