Question about M-Audio Studiophile AV 30 Computer Speakers
The main speaker with the amplifier on my M-Audio AV30 has very weak volume and the other speaker is working fine. Any suggestions.
    New Friend:
Had the same problem and found a blown transformer in it....hope this helps.
Posted on Jan 11, 2013
  • Steve Atkins Jan 11, 2013
    had the same problem and found a blown transformer in it....hope this helps.
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Apr 01, 2011
Two main speakers, 8 ohms each for the stage, two smaller speakers for back of hall, of 6 ohms each. One rheastat available. How do I connect these to the amplifier, please?
You don't need to use the rheostat. If your receiver is 8 Ohms you can run all the speakers to the amp one speaker per channel just fine. Just leave the amplifier on 8 Ohms. It will be fine. Use the reviver gain and volume as you normally would.
Regards, Tony
Mar 24, 2011 | Audio Players & Recorders
I need to find out what amp fuses go into my M-audio studiophile AV30 speakers. please help.
The main speaker with the amplifier has very weak sound but the other speaker is working fine. Any suggestions.
Sep 23, 2010 | M-Audio Studiophile AV 30 Computer...
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Faint sound from the speakers
Most speakers are mains powered (either plugged directly into a wall socket, or maybe using a 12volt adaptor), and inside the speakers will use a small amplifier circuit. These circuits are prone to often going faulty and may lose one speaker or both, so instead the speaker will then only play the sound as it gets it from the PC (or hifi etc.).
Audio to speakers is not sent in a 'loud' form, but is instead just a very high quality weak signal that must be amplified to be heard. Typically a PC sound output may be just .5 to 1.5 volts only, just enough to work a set of headphones but nothing much more.
I suggest checking your speakers on another item, such as a CD player or hifi that definatly works, and if its the same, its most likely the 'amp' gone faulty. It's not really worth fixing as they usually only break in cheaper types of speakers - so its as easy to just buy another set.
If they work OK on other devices, maybe check these things:
Is the volume up on the computer ? Check on the volume icon on the taskbar, and also if its a laptop check its not got a volume dial that has been accidentaly turned down/off.
Test the computer with other speakers, to just narrow down the fault.
Some PC's have several output sockets at the rear (or front), so make sure you have it plugged in to the correct socket - even if you have used it before, some PC's software can actually change what comes from each socket, so your MIC socket could now have become your SPEAKER socket, or other settings may have been changed by other software.
Check your operating system is not using a 4 speaker setup instead, and sending the sound to non-existent rear speakers/woofers/tweaters. My own PC has 8 outputs, so I make sure nothing alters my settings or i'd never hear it again ;)
Its also possible for the PC audio chip to go faulty, but that is very very rare. If nothing else works & the speakers are known working ones, you may have to try a new sound card.
Remember that plugging the standard 3.5mm stereo jack plug into the wrong sound card socket will not cause harm, you may just hear a loud 'THUMP' or click as the power goes across.
One last thing is, try reinstalling your audio drivers. PC operating systems can lose driver functions and do any possible thing you can imagine. It may be as simple as a reinstall to wake up the audio card again.
Good luck.
Dec 16, 2008 | Audio Players & Recorders
No audio to speakers from deck, just to amp
It's possible (probable) that the head unit has a blown internal amplifier IC. Measure the DC voltage on each of the 8 speaker wires on the head unit. Place the black lead on the chassis of the head unit. Probe each wire with the red lead. All should read approximately 1/2 of the voltage on the yellow wire. If you get some that are significantly higher or lower, disconnect all speaker wires from the harness and measure again. If the voltage is still not ~1/2 of the voltage on the yellow wire, the IC is almost certainly defective.
For the external amp, you need to check the shield ground for the head unit. The following page shows you how.
Test RCA shield ground
Apr 21, 2008 | Pioneer GM-X372 Car Audio Amplifier
Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
Buzzing sound thru speaker even with volume down to zero
maybe some filter capacitors of the amplifier has been drying out! check for the main filter capacitors and output capacitors of your amplifier. replace them if necessary with a higher capacitance but the same voltage rating!
Nov 16, 2007 | Onkyo TX-DS696 Receiver
Car amplifier weak
if you have a 25 Watt amp (per speaker) then go to radio shack and get (2) 50 watt resistors (8 ohms each). attach them like speakers. turn it on half volume. they should get quite warm to the touch.
Jun 10, 2007 | Jensen A300HLX Car Audio Amplifier
M-Audio Studiophile AV 30 Computer Speakers Logo
590 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
