Question about Maytag Dryers
Maytag performa no lights come on and does not work breaker is on
  • 415 Answers
A short in the wiring at the unit could be the problem, shut off the known breaker to the unit and remove the lower toe panel and open up the wiring connection box and see if that is the problem.
Posted on Apr 01, 2011
  • fixrguy Apr 01, 2011
    I am sorry I was assisting another and that was for a dishwasher, now for your dryer it sound like a thermal fuse link has failed and and repair is required. A semi- time and knowledge based repair.
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
Looking for heating element breaker or reset on a performa dryer
you have to take off the back its to the bottom left
Aug 31, 2009 | Maytag Dryers
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
No power to maytag duet dryer...no light no power I have checked circuit breaker plugged/unplugged??
most maytag "performa" dryers with no power h appen froma blown thermal fuse. It is located under the top and beside the heating element. you can take an ohm meter to both terminals.If you do not get a reading, the part is bad. It comes as a kit with a new safety tstat
Feb 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Dryer won't come on
motor relay on control board, thermal fuse or breakers are tripped, check breakers 1st
Dec 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Jun 05, 2008 | Maytag Performa PAV2200
Dryers Logo
35 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
