Question about KitchenAid KUDE60FVSS 24 in Builtin Dishwasher
My new dishwasher ( KitchenAid Model # KUDE60FVSS3).Water remains in the tub after the cycle is finished. I have taken out the water and ran another load but the same thing happens. I have checked for obstructions and have taken the filter out and checked it. All seems OK. Do you have any other suggestions before I call my plumber.
hotuna
  • 288 Answers
SOURCE: kitchenaid dishwasher - water standing at end of cycle
How much water are we talking about? If its say less than 2-3 cups, It may be the way it is plumbed to drain. The drain line is back washing a little after everything is finished.
Posted on Dec 03, 2007
gwshaw71
  • 83 Answers
SOURCE: Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Posted on Dec 07, 2007
SOURCE: tub water dirty
Removed 2 separate filters that were heavily clogged and cleaned them.
Posted on Jul 17, 2008
SOURCE: Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Posted on Nov 15, 2008
ginko
  • 19396 Answers
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
Posted on May 21, 2009
I have a kitchenaid dishwasher model number kudso2sr and there is standing water in the bottom of the unit after the cycle is complete. The water will not drain. I ran another cycle and the water still...
you may have a vacume issue
along side of the dishwasher itself there is a loop of drain hose to create a trap - inspect. also inspect where it is hooked up & follow where the drain hose goes to it's final connection to be sure there are no up hill runs or other blockages.
Speaking of blockages,. did you inspect the dishwasher drain very well to be sure it is fully clear and somethign is not stuck in under the water?
If need be pull the machine out from under the counter and check the side hose and unhook the drain where it goes into your house plumbing...
Dishwashers can be cluegy when it comes to draining...
Jan 05, 2011 | KitchenAid 24 in. KUDS02SR Built-in...
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Standing water in tub after all cycles are finished
some water should remain in tub so that pump does not lose prime
Oct 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Water remains standing in the tub
take off the filter and there is a screw under the filter remove that screw to see if there is anything in there.that might be a blockage causeing not all the water to drain.
Dec 30, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
KitchenAid KUDE60FVSS 24 in Builtin Dishwasher Logo
273 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
