Question about Meade ETX-105AT (420 x 105mm) Telescope
Purchased ETX105 2004 with Autostar Suite and LPI with Windows XP onPC Successful Photds. Changed now to Vista Laptop PC which will not recognise telescope or camera. Understand a need to instal a driver.Please advise instructions',,equipment, quotation,U K.supplier. Is my understanding correct. Please Advise rRegards Frank Ashworth
  • 3,186 Answers
There are NO 64 bit drivers for the LPI camera-- this is all that Meade has for software for the DSI camera ---
http://www.meade.com/support/downloads.html
See the Envisage software-- it will not work with the LPI which is no longer produced.
Posted on Apr 02, 2011
  • fashwo811215 Apr 03, 2011
    still investigating new software driver for LPI camera with Vista. Close to conclusion that Celestron Neximage Solar System imager camera with it's own software, separate from Autostar solves the problem so I've ben old
  • Joe Lalumia aka TelescopeMan
    Then WHY would you give me only a 2 thumbs up ?? for a correct answer to your problem?
Can not use my autostar or lpi camera on vsta as there seems to be a driver error
Try right clicking the program EXE file and running it in XP mode.
Also install the latest autostar software on the Meade web site:
Jan 06, 2011 | Meade ETX-105AT (420 x 105mm) Telescope
Suite does not open port to DS 2080 telescope
What computer are you running? XP? Vista? Windows 7?
Also if you do not have a real serial port on the computer then you must use a USB to Serial adapter cable.
There is also new software on the Meade web site here:
Oct 05, 2010 | Meade Autostar Suite Autostar Suite...
DSI3 driver doesn't work with Windows Vista
You may want to check the downloads section at Meade for an updated program.
Aug 20, 2009 | Meade Autostar Suite Autostar Suite...
Lpi issues with windows xp
Did you install the driver (CD) that came with the camera-- and are you using Windows XP-- there are known issues with Vista.
Mar 26, 2009 | Meade ETX-90PE (325 x 90mm) Telescope
Vista will not work with autostar 494
I did some research on meade 506 astrofinder software
Read this...
Customer Review:
Rating: stars-1.0.gif
Summary: outdated software
The software this kit comes with is old and outdated. It is not supported by Windows XP nor Windows Vista. The latest supported version of Windows is Windows 98.
It also appears that the included software is a limited trial software. It is limited to the included 3 catalogs (star maps). The complete set of catalogs must be purchased additionally at quite some expense.
The cable connection kit couldn't be reviewed because it was missing from the package I received, but keep in mind when you order this kit, that neither Windows XP nor Windows Vista support serial ports anymore. The additional USB to serial adapter would be required.
That last line would suggest to me that if one had a USB to Serial adapter it might work? but I really do not know for sure. checking into some more stuff...
Found another article that states "It requires a PC running Windows 98SE through Windows XP. It will not run under Windows 95 or earlier, nor will it run under Windows Vista."
OK I found this site, you might be able to make some sense of it. But I did read in there that they do make USB serial adapters that will work with Vista OS.
Good Luck and happy star gazing! If you find something new out there maybe you could name it after me if you get it working. lol
Mar 07, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
My computer will not recognise my meade lpi camera
This is a known problem with VISTA--- works fine in XP--
However make sure you have the latest version of Autostar Suite and Envisage from the Meade web site--
Nov 27, 2008 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade ETX-105AT (420 x 105mm) Telescope Logo
105 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
